Quote Originally Posted by Turbocharged400sbc View Post
for the "idle" trans we use a flat towing trans circulation pump to keep the guts of the rear trans wet while in neutral with the engine off.
We were planning on doing this if we were to street drive a lot. Right now what I do is leave the engine running in neutral but I never go far without both engines running. The rear engine does not have heat problems at all. it runs 190F steady in 80F weather. I can leave it running. The front engine has a lot of strain if it's the only running engine even for cruising. It's best to leave both running it runs better that way although a little harder on fuel.
for short distances after being recently started and shutoff he should be fine since its mostly a racecar.
the Tq converters will stall as much as they need (slip) to equalize the load depending on the traction/load, that the beauty of a viscous tq multiplying drive. when launching the rear see's everything (one reason our 25.3 chassis is using 4x4 LCA hardware/heims and extra bracing)
so yer probably right the 1-2 did it in. but keep in mind that 400ftlbs is plenty to break a stock IS when the shock load can have the converter multiplying that up to 1000+ for a split second. plus without the rear driving a SC yer already 50+hp more than the front engine just from the crank not spinning it.
I will be forcing the trans in 2nd gear for launches. With more boost it will launch just as hard. When the front engine will be turbo, it will also leave in 2nd gear.
you may want to look into the 3.71fdr 80e though i dont think it will clear your unibody rails, thats just a mallet and a few licks away....
looking good guys.
kinda make me pissed we havent gotten more done on the 442 in the 14 year build/rebuild/rebuild lol
Thanks ! Yes it will probably motivate you to do a last push to complete your own crazy project.
AS for the 4T80E it's a heavy pig, and the weight is already an issue. I am genuinely worried about being able to slow down without a parachute. It will be hard to slow down from a 145 mph trap speed at 4500lbs + race weight on stock size GTP brakes. I'd love to go bigger but I won't be able to run my slicks up front.
Also how much wider is it from the block to the body ? I only have 2 inches between the trans and the rear frame rails or 1 inch between the factory trans mount gusset to the rail.
