Thread: Twin engine GTP project progress thread
Page 12 of 24 FirstFirst ... 2101112131422 ... LastLast
Results 221 to 240 of 469
  1. #1 Re: Twin engine GTP project progress thread
    Jul 2010
    Coquitlam,BC,Canada
    Very cool. Glad to see it at this stage.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #2 Re: Twin engine GTP project progress thread
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    Quote Originally Posted by Turbocharged400sbc View Post
    keep it there you dont want that weight at the back of the vehicle. our new chassis is goin to only have the fuel cell that's at the rear of the car...it looks like we might be able to do saddle fuel tanks in front of the rear engine with the new radiator set up...but the fallback is at the rear...away from the driver lol
    your goin two want to try to keep as much of the weight towards the CoG.
    Yes we did do that. Surprisingky the car is well balanced and with the new suspension configuration it really helps keep the front wheels useful.
    I need a much stiffer shock because with all the preload there is a little pogo effect. Otherwise it drives very nice and feels very stable and launches in straightline
    Sent from my iPhone
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  3. #3 Re: Twin engine GTP project progress thread
    Jun 2014
    Wichita, KS
    You guys are killing me. I have so many parts cars laying around...really makes me want to twin engine my Park Avenue, it wouldn't cost much, just a lot of time and fab.
  4. #4 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    We installed the parts car trans in the back and will be doing 2nd gear launch to see if that can help keep the trans healthy.
    Just ran out of time finishing the install to go racing.
    Sent from my iPhone
  5. #5 Re: Twin engine GTP project progress thread
    hangover park IL
    yeah we have to utilize double adj mustang front struts in the rear to have any compression adjustment
    its sucks that we cant use any differential reaction forces on our heaps....
    ~James~ Psychotic Gearhead
  6. #6 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    How's the fitment on those struts in the back ?
  7. #7 Re: Twin engine GTP project progress thread
    SE Level Member AndrewZ28's Avatar
    Jun 2014
    Houston, Texas
    Insane project! Now I really want a turbo...
    2003 SE TONS of Mods= New O2 Sensor, New Headlights, New EGR Valve... About 345whp
    Quote Originally Posted by Iceman6669 View Post
    It's a Grand Prix... There's always a problem
  8. #8 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Thanks.
    In my opinion these engine are really made to be turbo.
    A lot less kr and much more power. In my 07 turbo gt im running 19-20psi daily on pump and methanol inj. With 17 deg advance
    Sent from my iPhone
  9. #9 Re: Twin engine GTP project progress thread
    Feb 2009
    flintnasty MI
    if you take a 30lb/m compressor off and put a 70lb/m compressor on... with an intercooler.... its probably going to make more power.....
  10. #10 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    That's not the point I was trying to make...
    These engines when all stock, are Iron head Iron block. Which means low heat dissapation potential. That means KR !
    Now add a Non intercooled M90 on it and you got a stock engine with a lot of KR even with low timing.
    The same M90 on a full aluminum head and block with slightly lower compression could run a lot more boost and power without knock.
    The turbo makes it easy to intercool properly plus it's more efficient. That all translate to being to run a lot of boost with no knock and more timing.
    That's why I say they are made to be turbo. They don't have the right specs to take advantage of M90 on pump gas.
  11. #11 Re: Twin engine GTP project progress thread
    Feb 2009
    flintnasty MI
    dumb.
    The m90 mustangs made 340whp intercooled on big displacement crap.
    3800s will do that unintercooled with a cam and a decent exhaust.
  12. #12 Re: Twin engine GTP project progress thread
    Arizona
    Lol^^
    Dark, a m90 mustang with a v8. is only on 7psi, the 3800 at around the same power level has more than likley dropped down to a 2.8, do the same on that mustang and see what happens. just saying thats a really dumb analogy you made
    anyways twinGTP check these shocks
    http://www.americanmuscle.com/qa1-si...ntV1&year=2011
  13. #13 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Anyways twinGTP check these shocks
    These are the right lenght for the GTP ?
    IN the back I ended up with the factory shocks/springs but they are heavily preloaded to reduce squatting to a minimum.
    I would need struts or shocks that are extremely stiff that are rear stock style.
  14. #14 Re: Twin engine GTP project progress thread
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    I tip my hat to you. Pure awesome
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  15. #15 Re: Twin engine GTP project progress thread
    hangover park IL
    single adjustable is useless you need to have compression adjustment so it's a double adjustable that you're looking for
  16. #16 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Right now with what I've got just a stiff rebound would work well as I can already adjust spring rate. With the high spring rate comes the pogo effect with tired stock struts.
  17. #17 Re: Twin engine GTP project progress thread
    hangover park IL
    I'm not talking about the spring or any of that the rear compresses so you're gonna want the valving stiff so that it sets down slowly.
    if he's going to get conventional single adjustable rebound the only good option is to only put them in the front.
    in the rear just get regular replacements. stiffer rebound in the rear is gonna do nothing for you. at least up front and they will help keep the front end from lifting as fast
  18. #18 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    When you get on the brakes on the top end, the rear rebound is super important. It prevents too quick of a weight transfer up front. In my case the springs are soo stiff that weight transfer isn't an issue however the Shock rate can't keep up and then you get the wave effect from front to back. That said It's not that bad at reasonable speed.
    We did some 1/8 mile testing and it ran great no problems, didn't feel dangerous but we are trapping 6.8 @ 103 mph right now with the same power as on the video (60%)
    But on the end of the 1/4 mile that is 132 mph+ and getting on the brakes might start a dance from front to back.
    Not counting the fact I will be making a lot more power in the back and will be turbo in the front. So traps will be MUCH higher as well as E.T. much lower.
    At the moment we are converting the front engine to turbo.
  19. #19 Re: Twin engine GTP project progress thread
    hangover park IL
    yeah you should play with your engine braking tables.
    it makes a crapload of difference though you will want to reflash it if you're gonna drive it on the highway cuz otherwise it's quite annoying
  20. #20 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
  1. Replies: 164
    Last Post: 10-03-2015, 09:07 PM
  2. Replies: 89
    Last Post: 11-20-2012, 11:30 AM
  3. push button start (progress thread)
    By z3r0 in forum Visual/Body Modifications
    Last Post: 12-01-2011, 08:38 PM
  4. my progress thread
    By Dragonblaze in forum Off Topic Discussion
    Last Post: 07-06-2011, 01:26 AM
  5. The new guy: Matto's Project build thread!
    By Matto211 in forum General Tech Discussion
    Last Post: 01-10-2009, 07:47 PM
