Thread: Gen v swap issues
Results 1 to 20 of 28
  1. #1 Gen v swap issues
    Howell, NJ
    The gen v is finally on.I have 2 main concerns.
    1) I'm not making any boost my aeroforce says 1lb max
    2) I'm over heating. I removed the thermostat because I'm pretty sure it wasn't opening up. *But it's still running hot.
    It idles fine. I'm using the stock gen v evap. And i tapped the tb and ran a line to the nipple on the supercharger.
  2. #2 Re: Gen v swap issues
    Ok, you Gen v'd... what was your previous setup? Which parts did you reuse. Did you get the cooling system to burp and take about a gallon or two?
  3. #3 Re: Gen v swap issues
    Howell, NJ
    Previously I was just a stock l67
    The only thing I reused was the stock throttle body.
    Im using the gen v BBV, vacuum tree, and lim.
    I couldn't get the damn thing to burp. I put the un mixed stuff in, 1 entire bottle of that. Then I could only get a little less than half the water needed in there. I had it jacked up and everything. And only water came out of the bleeder valve.
  4. #4 Re: Gen v swap issues
    1.5 gallons is around the right amount. So that should be good. Toss a new thermostat in there. Start it.. turn it off.. check it like that a few times.
    Boost.. did you use a different soleniod or the one from your old Gen 3? Swap it if you used a different one.
  5. #5 Re: Gen v swap issues
    Howell, NJ
    Are you talking about the boost by pass valve? If so I'm using the gen v one.
    Wheres the solenoid located.
  6. #6 Re: Gen v swap issues
    Right in front of the valve.
    The round can wtih the rod is the valve. aka Boost Control Actuator
    The little rectangle with the electrical plug is the Boost Control Soleniod
    If you used the soleniod from the gen V..swap your old one on..
  7. #7 Re: Gen v swap issues
    Howell, NJ
    Would having no thermostat cause it to over heat???
  8. #8 Re: Gen v swap issues
    It might.. the theory is that the coolant doesn't spend long enough in the radiator w/o a stat.
  9. #9 Re: Gen v swap issues
    Howell, NJ
    It's still over heating....
  10. #10 Re: Gen v swap issues
    Howell, NJ
    Okay my aeroforce is telling me the coolant is at 185 while the one on my dash is almost in the red
  11. #11 Re: Gen v swap issues
    Banned
    Jan 2013
    Colorado
    Try putting the old blower back on to see if that helps.
  12. #12 Re: Gen v swap issues
    Howell, NJ
    Thanks for the advice but I'd rather not.
  13. #13 Re: Gen v swap issues
    when I did my genV swap I had to use my genIII version as I was only getting ~2psi wot. Give that a shot. Did you check for vac leaks?
  14. #14 Re: Gen v swap issues
    Howell, NJ
    I'm probably going to do that but I'm more worries about the over heating issue.
    Or if it's an issue at all. Gotta figure out which gauge is lying to me
  15. #15 Re: Gen v swap issues
    Feb 2008
    You may have messed up the coolant temp sensor in the LIM, or have a wire shorted out. Check your connection at the sensor and where that harness ties into the main harness near your oil cap.
    Sent from my SkyRocket
  16. #16 Re: Gen v swap issues
    Howell, NJ
    I replaced the coolant sensor when I did the swap... I broke the old one.
    The gen v is hot to the touch which I'm pretty sure is abnormal, am I right?
  17. #17 Re: Gen v swap issues
    No, Im ICed and mine still gets pretty warm to the touch. I have and always will trust my aero over my gauges. Id say you have a bad temp sensor/was installed improperly.
  18. #18 Re: Gen v swap issues
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    If I am not mistaking the l67's use two different temp senders. I think one for the computer/fans and another for the gauge. I may be wrong though.
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  19. #19 Re: Gen v swap issues
    Howell, NJ
    So the aeroforce gets its reading from a different sensor?
  20. #20 Re: Gen v swap issues
    Howell, NJ
    The aeroforce is reading the correct temp.
    If my motor was really at 260 the temp light would be on and I would be getting a code.
  1. gt to gtp swap with issues!! help
    By SHORINJINN in forum General Grand Prix Discussion
    Last Post: 03-12-2013, 12:27 PM
  2. Tranny swap now having issues
    By RANDY99GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2012, 06:05 AM
  3. Post Top Swap Issues 2005 GT
    By acidcrashdburnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2012, 12:52 PM
  4. I have some issues after Top Swap NEED INPUT
    By WindsorGP in forum General Tech Discussion
    Last Post: 08-17-2010, 05:35 PM
  5. mid-motor swap issues
    By darntootin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-07-2009, 04:45 PM
