Thread: replacing exhaust manifold gaskets
Results 1 to 9 of 9
  1. #1 replacing exhaust manifold gaskets
    GT Level Member al2000gtp's Avatar
    Buda,IL
    I seafoamed my car bout a week or two ago and found that im leaking pretty bad out the rear manifold. Can I just rock the engine foward and unbolt the headers and replace that way or is there more to it than that?
    2000 GTP - HAI, SD Headers, 3" catback, cat delete, thrush turbo muffs, self ported sc, and transgo shift kit.
  2. #2 Re: replacing exhaust manifold gaskets
    thats about it if your just changing the gaskets.
  3. #3 Re: replacing exhaust manifold gaskets
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    You'll probably have to loosen/remove the crossover as well. But you have the right idea
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  4. #4 Re: replacing exhaust manifold gaskets
    Buda,IL
    Alright, Thanks guys.
  5. #5 Re: replacing exhaust manifold gaskets
    St. Louis
    May want to try and spray some PB Blaster on those manifold bolts before you try removing them. Should lessen the chance of one snapping off.
  6. #6 Re: replacing exhaust manifold gaskets
    Buda,IL
    Thanks fordman. Hoping it wont be too bad since headers have only been on there for about 9k. Should i loosen each one a little at a time to keep them all even?
  7. #7 Re: replacing exhaust manifold gaskets
    St. Louis
    In that case it should be ok. In your opening post you said "rear manifold" first, then later you said "header" so I wasn't 100% sure you had actual headers or not. As far as unbolting them a little at a time I'd say it shouldn't matter I would think.
  8. #8 Re: replacing exhaust manifold gaskets
    You can take them out one at a time. It won't hurt anything.
  9. #9 Re: replacing exhaust manifold gaskets
    Buda,IL
    Alright thanks again guys
  1. Changing out intake manifold gaskets
    By Drummer9103 in forum General Grand Prix Discussion
    Last Post: 04-29-2013, 04:16 PM
  2. 3800 Series III (L26) Manifold Gaskets
    By dturchi in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-26-2013, 10:27 PM
  3. Replies: 7
    Last Post: 12-25-2011, 08:02 PM
  4. Intake manifold and VC gaskets...
    By bowsox88 in forum General Tech Discussion
    Last Post: 02-15-2011, 07:52 PM
  5. Exhaust Manifold Gaskets
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 12:22 AM
