Thread: Burning through wheel bearings?
Results 1 to 20 of 40
  1. #1 Burning through wheel bearings?
    Dec 2008
    Indianapolis, IN
    I've got an 03 GT and this is now my fourth replacement for the front wheel bearing (two left, two right). I've had them all done at Big O' Tires (I don't have time), and the replacements have been under warranty (< 1 year). I've got 242k miles, but most everything up front is new: shocks, control arms, CV axles, tires, etc. Steering isn't loose, alignment is perfect. Is it something they're doing that's burning these up? I'm using the lower-end stuff from CarQuest (it's next door to them, so that's where they buy), but I'm thinking of having them upgrade to a Moog assembly. Can installation problems lead to a bad bearing?
  2. #2 Re: Burning through wheel bearings?
    GT Level Member fireprix's Avatar
    Virginia
    Thats a big issue in these cars, from what I understand, lower end stuff tends to burn up pretty quick, why alot of folks spring for the Timikin (sp?) set. Gotta get the torque right or that'll increase the wear too, I've replaced mine twice, second set lasting much longer now that I've made sure I got the torque specs right. Someone else may be able to chime in better.
    2004 GP GT2 -- Sold
    2009 G8 GT -- Moar Power
  3. #3 Re: Burning through wheel bearings?
    Feb 2013
    37.295091, -121.930053
    its could be they have no clue how to install them strait. If they are not intalled correctly or packed right then it would cause premature ware and failure. Ask them if they are packing them.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: Burning through wheel bearings?
    The OP's car has hub and bearing assemblies.
    You can't really screw it up unless you don't tighten the bolts or leave layers of crap between the hub and spindle.
    Quote Originally Posted by Teancum View Post
    Sounds like a good idea.
  5. #5 Re: Burning through wheel bearings?
    Eric doesn't appear to have installed a bearing on a W body from 97-08 yet. There is no alignment of the bearing, there is no packing of the bearings and there is nothing you can do but use a better brand.
    I ripped through many Timkens, I believe they used to be made better and pushed production to Hong Kong or Mexico in the last couple years. Currently I'm very happily running SKF in the rears (3 yrs 55K miles no issues) and Moogs up front (because Advance had a 3 yr warranty and $40 off $100 discount code) so far so good.
    On torque, yes there's a spec. No.. I've never used one and done a lot of these. Hasn't led to premature wear at all. As well a mechanic buddy has done more than his share, never torqued with the same results. Aka that's where I got the bad habit.
  6. #6 Re: Burning through wheel bearings?
    cheap wheel bearings like to fail.
    they could also be not torquing things properly.
  7. #7 Re: Burning through wheel bearings?
    Dec 2008
    Indianapolis, IN
    Thanks for the ideas. Is there a quick reference on the torque specs? I think I'll have them fix it, pay the difference on the part for a Moog upgrade, and hand them the torque specs. Maybe I'll even bring the part in myself. They treat me really well there, but I get the feeling their techs are not ASE certed.
  8. #8 Re: Burning through wheel bearings?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    147 ft lbs. get SKF parts for wheel bearings only.
  9. #9 Re: Burning through wheel bearings?
    Pennsylvania, USA
    I've only heard hood things about SKF and Timken. I went with the Timken for my rear right because it was cheaper on Rock auto.
    Funny thing is I replaced my front right with a cheaper Cardone wheel hub from Amazon back when I first got the car, and a year and a half later it's fine. I got lucky so far...
  10. #10 Re: Burning through wheel bearings?
    Apr 2012
    Goderich, Ontario
    I've burned threw 3 in the last 2 years, free on warrenty from NAPA. The good thing is I've gotten pretty good at changing them out. The driver side requires 118lbs of torque and the passanger side requires approx 108lbs of torque to tighten.
    -Paul Walker
  11. #11 Re: Burning through wheel bearings?
    Quote Originally Posted by addzradd View Post
    Quote Originally Posted by smoke14 View Post
    Both are 118 ft lbs.
    Haynes manual is wrong most of the time, Alldata and the GM website my work uses have the correct specs.
  12. #12 Re: Burning through wheel bearings?
    GT Level Member Shiftingshaddow's Avatar
    KC
    you have to get the higher end wheel bearings for ALL GM front drives of this generation. they are the same part--interchangeable on almost all gm front drives. they all chew these up. there is a lot of stress on the wheel bearings because of the weight on them being in the front plus they are part of the drive train so they have to handle that force as well.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  13. #13 Re: Burning through wheel bearings?
    Feb 2009
    flintnasty MI
    i only run "used" oem bearings from low mile cars.
  14. #14 Re: Burning through wheel bearings?
    Banned
    Jan 2013
    the bandwagon follower aka noobiee
    get oem parts =[
  15. #15 Re: Burning through wheel bearings?
    SE Level Member Reverant GTP's Avatar
    Iowa
    I've run nothing bit Moog and have no problems here. The box they come in have the torque specs in them for either reusing old cv nut or buying a new nut. I always buy a new nut as its recommended to be replaced. Coming from auto parts background the cheap bearing on gm is a definite no. I warrantied them all the time and every time told them to upgrade... it took a few time but eventually they did.
  16. #16 Re: Burning through wheel bearings?
    Dec 2008
    Indianapolis, IN
    I broke down and took it to the dealer. OEM has a lifetime warranty, and after it and an oil change it'll be about $550.00, but right now I have plenty of money and very little free time. Plus I love the idea of a lifetime bearing. That's assurance, right there. Considering I've dropped $360 with two previous bearings I'd rather do it once more and do it right. Wish I could've saved money doing it myself, but this is one of those rare times where money availability trumps free time.
  17. #17 Re: Burning through wheel bearings?
    Feb 2009
    flintnasty MI
    about $550.00
  18. #18 Re: Burning through wheel bearings?
    Dec 2008
    Indianapolis, IN
    Yeah, I know. But they're offering shuttle service so I can actually work instead of taking the day off to fix my car. When I factor in the money or time off I'd lose trying to fix it then it pays off.
  19. #19 Re: Burning through wheel bearings?
    Arizona
    A day off? All you need is a hour tops a jack a 36mm socket 21mm deep well 17mm 16mm breaker bar 1/2 inch ratchet and a hammer lol
  20. #20 Re: Burning through wheel bearings?
    Dec 2008
    Indianapolis, IN
    Quote Originally Posted by 91parkave View Post
    Last time I tried the tie rod's nut got stuck. I had cleaned/lubed it all properly so it would come off easy, but once it got to a certain point it wouldn't budge. It eventually did, or so I thought. It popped the tie rod out of place, meaning now I had nothing to torque against. I have only one car, so I had no way to get additional tools. I had a nut splitter, but no replacement nut.
    Needless to say I could not afford to risk that again. My car loves to demonstrate Murphy's Law when I work on it.
  1. wheel bearings
    By whit in forum General Grand Prix Discussion
    Last Post: 09-19-2012, 05:58 PM
  2. Wheel Hub Bearings??
    By misterman in forum General Tech Discussion
    Last Post: 05-28-2011, 09:06 AM
  3. Wheel Bearings?
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2010, 08:05 PM
  4. Wheel Bearings
    By JAllegar in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2009, 02:57 PM
  5. wheel bearings
    By 98GTPCALGARY in forum General Tech Discussion
    Last Post: 06-11-2009, 02:45 AM
