Thread: Help Please!!!
Results 1 to 10 of 10
  1. #1 Help Please!!!
    Mar 2012
    Michigan
    01 grand prix gt 3.8L not super charged, I have replaced the thermostat sensor and thermostat,today because I thought that was the reason my temp gage was going up, well it turns out that was not the issue because my temp gage still wants to go up to the 250 mark. Is there any way to check to see if it might be my heater core, when I turn the heat on the gage drops down to the 170 mark or is it my radiator.
    Sammie
  2. #2 Re: Help Please!!!
    Did you bleed the air out of the cooling system?
  3. #3 Re: Help Please!!!
    Mar 2012
    Michigan
    yes
  4. #4 Re: Help Please!!!
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Do it again.
  5. #5 Re: Help Please!!!
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    ^X2
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  6. #6 Re: Help Please!!!
    Mar 2012
    Michigan
    Did it again,still the same. Is there a way to check to see if the heater core is going out
  7. #7 Re: Help Please!!!
    turn the heat on, if it blows hot air you got heat. and the core is ok.
    do the fans come on?
  8. #8 Re: Help Please!!!
    Jul 2012
    Possibilities
    1 Fans not working
    2 radiator/coolant passages gunked up
    3 coolant pump failing
    4 gasket leak
  9. #9 Re: Help Please!!!
    Mar 2012
    Michigan
    Thanks to all of you for your help.... I took my car down to have it checked ,the guy told me that he hooked my car up to a scanner to see what was going on and it seems that my car is running fine,but I have to take it into the dealer because he said it is either my cluster or my new sensor isn't giving the thermostat gage the right reading.
  10. #10 Re: Help Please!!!
    A guess would be the new sensor, because if I remember correctly it sends two signals for the temp. One goes to the cluster and the other to the cars PCM, so the PCM may be getting the correct temp, but the cluster is not and that is why it seems that its getting so hot.
