Thread: Burning through wheel bearings?
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #1 Re: Burning through wheel bearings?
    What's the 21, 17 and 16 for?
    34/36 for the axle nut
    19mm for the lug nuts
    18mm wrench..pop BJ and you don't mess up the alignment
    13mm for the bearing bolts
    Hammer
  2. #2 Re: Burning through wheel bearings?
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    ...pop BJ and you don't mess up the alignment
    Your way of doing this suddenly sounds SO much more fun than mine...
  3. #3 Re: Burning through wheel bearings?
    ^ This. Doesn't take to long personally I would never pay that to have someone else do it.
    04 Comp G.
  4. #4 Re: Burning through wheel bearings?
    Arizona
    Oddly enough my bearing bolts on The Gxp Were that size 16mm and to be quick about I just pop the strut to knuckle bolts loose since my I have a lifetime alignment deal forgot my gtp had the 13 mm bolts
  5. #5 Re: Burning through wheel bearings?
    Tie rod?
    Bill's method:
    Jack and support the side in question
    Remove tire
    Loosen axle nut, leaving it just proud of the axle
    Hit end of nut with BFH to free axle from bearing
    Remove nut remainder of the way
    Remove the caliper and bracket, support the caliper and remove the disc
    Disconnect the ABS sensor wire at the hub
    Sneak in to get the 3 13mm bolts that hold the bearing to the knuckle (if they seem questionable use a 1/2")
    Smack rear of hub with BFH to break it free.
    Wiggle it off and new one in place, ensure you put the backing plate on in the correct orientation for the sensor wire.
    Bolt it all back together.
    See...that was quick and nice, right?
  6. #6 Re: Burning through wheel bearings?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    The only difficult one is the top one, but if you hold back the axle you can get a 1/4 inch drive in there with a 13mm pretty easily.
  7. #7 Re: Burning through wheel bearings?
    Or use a universal and a 13mm shallow plus an extension. It's honestly not that tough and if you can break it free with 1/4" stuff, then you are better than me or your bolt was loose.
  8. #8 Re: Burning through wheel bearings?
    Feb 2010
    Cleveland
    Just gotta use some muscle and have decent stuff that won't break. I tried the universal but I couldn't find a shallow enough 13 to make it all fit.
  9. #9 Re: Burning through wheel bearings?
    i used a shallow socket on the end of a 6 inch extension 3/8 ratchet. pop the tie rod so you can move the knuckle around, easy as pie.
  10. #10 Re: Burning through wheel bearings?
    Doesn't yoru steering wheel turn Scott? Pop the tie rod? .. I've never seen a need?
  11. #11 Re: Burning through wheel bearings?
    it does, but why crank the wheel and make the car move when its on a jack or stands, i never liked that feeling. plus its one nut and a hammer to pop it off.
    then you also need to get up and turn it back and fourth, pop the tie rod, you can turn it at will sitting in front of it, safely.
  12. #12 Re: Burning through wheel bearings?
    Guess having the tie rod pop and spin is more of an issue. I've never really needed to mess with it that much. I'm there to do a bearing, straight on has less pressure on everything.
  13. #13 Re: Burning through wheel bearings?
    truth is, in all my years of changing tie rods, i NEVER had one spin on me. dumb luck i guess.
  14. #14 Re: Burning through wheel bearings?
    Wow, you did get lucky. I've changed hardly any and since I'm using air..it's usually all good. But I've seen a few ugly ones.
  15. #15 Re: Burning through wheel bearings?
    Oct 2012
    Union, OH
    I've used Bill's method (before I knew it was Bill's method) on three different vehicles now ('97 Grand Am GT, 2001 Grand Prix GT, 2002 Montana) and never had any issues with it. Hardest part is usually getting the brake caliper bracket bolts broken free. Everything else is cake - just takes some patience to get that top bolt off the hub. PB Blaster helps...the ends of the bolts are exposed on the front of the hub, so soak that area with PB blaster and it helps alot. 1aauto has a great video of this method on You Tube, BTW...
  16. #16 Re: Burning through wheel bearings?
    Aren't you older.. like Scott. I'd be willing to say it was your method before it was mine..lol
  17. #17 Re: Burning through wheel bearings?
    Oct 2012
    Union, OH
    I don't think I'm old like Scott (he's said he's older than me, but not how much...lol)...I'm 38, but my first hub replacement was about 10 years ago, so you probably did that before me...and scottydogs is right - only so many ways to get that thing out...lol
  18. #18 Re: Burning through wheel bearings?
    theres only so many ways to skin a wheel hub.
    first one i ever did was a 3500 97 gmc 4x4 front hub, the rotor was pressed to the studs of the hub, 8 lug too. made changing the rotors so much fun.
    before that, all my cars had real bearings, that you had to grease every 10 years. best part is, they hardly ever failed.
  19. #19 Re: Burning through wheel bearings?
    Arizona
    I never took off the tie rod to do a wheel bearing
  20. #20 Re: Burning through wheel bearings?
    Apr 2012
    Goderich, Ontario
    I jack up the car so both front wheels are off the ground then place 2 jack stands under the subframe and turn the steering wheel to get at the 3 bolts.
    -Paul Walker
  1. wheel bearings
    By whit in forum General Grand Prix Discussion
    Last Post: 09-19-2012, 05:58 PM
  2. Wheel Hub Bearings??
    By misterman in forum General Tech Discussion
    Last Post: 05-28-2011, 09:06 AM
  3. Wheel Bearings?
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2010, 08:05 PM
  4. Wheel Bearings
    By JAllegar in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2009, 02:57 PM
  5. wheel bearings
    By 98GTPCALGARY in forum General Tech Discussion
    Last Post: 06-11-2009, 02:45 AM
