Thread: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
Results 1 to 20 of 38
  1. #1 How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    So a few months back I put a used zzp ssm90 kit on my car. I absolutely loved it and couldent have been happier. Fast forward to a week ago I was given a golden oppertunity to get a GenV blower that was grandma driven with only 100k on it for 290$. Asked around and everyone told me it probably wouldent work or that they didnt know if it would work.... So i did some measuring and thinking and decided to jump in, I ordered the blower and then ordered a northstar kit from zzp and gaskets and whatnot.
    Before shot
    Started to pull stuff apart
    Fuel rails off
    Blower is clear of obstructions
    Plugging all holes... Seriously I had to pull a cylinder head due to a buddy dropping a nut down his intake
    Checking how much im gonna have to cut off
    Green sharpie... because... thats how i roll
    Checking how much im gonna have to chop off to clear injectors
    Black sharpie now
    Follow the arrow
    Prepairing to catch metal shavings
    Cutting has begun... god im dumb
    Cut complete.. turned out pretty good
    Time to hurt the blower
    Poor thing
    Major cut to clear the fuel rail done
    My diy evap blockoff plate
    Cut for the injector
    It worked
    Gasket prep
    Everything coming back togeather.... northstar on
    Ready for first start
    Flashing maf tables
    Video of the first start.... Pardon the excitement
    First start of GenV swap on grand prix gt - YouTube
    It runs like a top... Needs quite a bit of tuning but good god does it pull hard. Dyno date is this coming thusday.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  2. #2 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Nice. Good work on that.
  3. #3 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Very nice, I like.
  4. #4 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Awesome conversion.
  5. #5 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Willoughby, Ohio
    YAY genV! looks good, nice job
  6. #6 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Nov 2011
    NY
    Niceeeeee!
  7. #7 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
  8. #8 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Are those injectors perpendicular to the LIM?
    Just curious because your intake valves might not stay as clean as if you had the proper injector placement.
    Might also make tuning rather a PITA as fuel would be evaporating off the runner walls at different rates depending on the LIM temp.
    How far off is the tune while it warms up?
  9. #9 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Apr 2011
    South Dakota
    Well its the ssm90 kit from zzp where they machine injector holes into the gtp lim. The injectors point straight up and down but are in basically the same spot as the stock gt lim. When i last had a look down the intake ports everything seemed ok. The tune was crazy far off but thats mostly from having to put the lq4 maf on the northstar tb. For whatever reason it was almost -15% long term trims in some places. I did two maf tunes and now its withen 5% but ill probably do one more. My wideband decided to die a while back so i had to use the stupid narrowband.... basically had to adjust fuel till the narrow looked around 940 and i had no kr. Dyno date with wideband is on Thursday.
    I love Decker<3
  10. #10 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    I live here. TLSheff's Avatar
    Are you running the 3.8 pulley on the GenV?
    If so do you have headers to put on, I wouldn't think the Plog and a D/Pipe would flow sufficiently for that blower on that pulley, with a high compression L36 lower anyways. Just don't want all the work to cause problems on the dyno. If its knocking hard make sure they don't try to tune past it.
    Boom Boom is a bad result after all this work.
  11. #11 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Apr 2011
    South Dakota
    I was running a 3.6 pully on the fully ported gen3 with absolutely no kr issues whatsoever. When im up at school (much higher elevation) I was even getting away with a 3.4 with no kr. The 3.8 pully on the genv is only giving me occasional spots of kr even with my guesswork tune and 20 degrees of timing. Once I get the wot fueling right im sure itll be fine again. Im not only running the 3 inch dp and plog, also ported my rear manifold, have er rockers, northstar tb (less inlet restriction = cooler boost), and a 180 tstat.
    Also i rented the dyno for 2 hours for ME to do the tuning. I dont trust anyone but myself. Gonna get my afr locked in at 11.5 to 11.7 and then add timing up the butthole. Then this summer im switching back to e85 and going with the 3.4 pully (I didnt buy the 60lb injectors for the spray pattern lol). Headers and a intercooler are also going on the summer.
    I love Decker<3
  12. #12 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Nice job!
    Lambokit to be built!!!!!
  13. #13 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    May 2012
    Where winter never ends
    yeah, I was there. I recoreded that video... just thought I would mention that since no credit was given. JK. but anyway, yeah the swap made a massive difference over his gen3.
    2000 Regal - Winter Beater
  14. #14 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Feb 2009
    flintnasty MI
    turn the timing down and lean it out.
  15. #15 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Apr 2011
    South Dakota
    Why... I usually shoot for 11.7 and then add timing untill i hit 20... After that ill lean it out to 12 and if its all still happy its time for a smaller pully
    I love Decker<3
  16. #16 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Feb 2009
    flintnasty MI
    Quote Originally Posted by frosty View Post
    seems like random numbers from the narrowband to me.
    Even still, if you can run 20 degrees, you can run 15 and more boost.
  17. #17 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Feb 2009
    flintnasty MI
  18. #18 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Apr 2011
    South Dakota
    Ill give you credit on the timing tip. You were 100% right.
    I still stand by my comment about only running a fat narrowband tune for a few days untill I was able to get on the dyno
    Turns out around 9500hz I was going into the low 12s even though I was in the low 10s at 7500hz
    I love Decker<3
  19. #19 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Apr 2011
    South Dakota
    Read about a sentence further.... I normally have a wideband... since mine died and i havent replaced it yet I have dyno time with a wideband at 1:00pm tomorrow.
    I love Decker<3
  20. #20 Re: How I put a GenV blower on a SSM90 intake. They said it wouldent work.....
    Pennsylvania
    Maybe I'm a tard for not knowing, but I'm curious about who manufactured your sc pulley... can't say I've seen any like it. Who makes that?
  1. SOLD
    By PokerBlakeB in forum For Sale - Parts
    Last Post: 05-03-2014, 02:29 PM
  2. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  3. Gen 5 blower on a ssm90
    By Frosty in forum General Tech Discussion
    Last Post: 02-17-2013, 11:48 PM
  4. Blower motor doesnt work
    By Eagle in forum General Tech Discussion
    Last Post: 09-21-2009, 07:41 AM
