Thread: Volt gauge reading high, "charging system failure"
Results 1 to 18 of 18
Threaded View
  1. #12
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Looks like it's data. Has a 12v source you could check voltage going in. A scanner like a tech2 could show what the bcm is seeing. The dic is either bad or the bcm is commanding those values. Any codes or weird lights coming on? Example abs or random dummy lights? Because at those voltages the car won't run. It actually be likely to see several bad modules caused by such a spike.
    I'd put money on a bad DIC but if the bcm is bad (which if it were you should see other weird things happening as well like no power door locks or lighting issues etc) Can you communicate with the bcm?.
    Edit that's for an 04. Let me check 05.. Okay Diagram shows the wiring is the same for the different years.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. Charging System Failure
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-03-2013, 11:51 AM
  2. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  3. Charging system failure w/HID's
    By zx7r4u2nv in forum General Tech Discussion
    Last Post: 03-12-2011, 12:37 AM
  4. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  5. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
