Greetings,
something wierd happend to me this morning. I had been driving for about an hour on the highway, outside temp was between -2 and +2 farenheit. I stopped at a convenience store for about 5 minutes. When I got back in and started the car, it cranked ok and started fine. About ten seconds later I got a DIC message "Charging System Failure" which lasted only 2 seconds. Instead of continuing to my destination I turned around and went home, just to be safe. The whole way back I kept an eye on the Voltage on the DIC, it read 15.4 the whole way, regardless of radio/heat/cruise.
I went up to Advance, where I bought my battery two months ago, had the system tested. The battery was reading 12.59V and the Alternator was putting out 14.5V under load. On the way there, my right front blinker blew, second time this year.
The guy at advance said that 15.4 is WAAAY too high, that I can start melting wires above 14.8. Thing is, since I had the car it has always run between 14.7 and 15.1 on the highway and 13.2 to 13.8 at idle. Today it idled no less than 14.4.
Any ideas?
thanks.
