Aeroheadcww
Unfortunately you cant avoid the stealership on this one. The bcm has to be programmed to your car. I changed mine because i was having charging issues that showed up intermittantly. I had to jump the car off a couple of times. It was easy to change, its under the driver side dash. The security relearn you can do a quick search for, its no big deal. Expect tons of errors until you get it programmed.
