Thread: Volt gauge reading high, "charging system failure"
Results 1 to 18 of 18
  1. #1 Volt gauge reading high, "charging system failure"
    SE Level Member Aeroheadcww's Avatar
    Williamsburg, Ky
    I was trying out some HID kits the other day, which I did not end up using. In the process I got a "charging system failure" notice on the DIC. I swithched to the battery voltage readout which reads around 27 volts with the engine running. I promptly shut the car off and it still reads 19 volts without the engine running. I checked the battery with a DMM and it read a normal 12 volts off and 14 volts running, which makes me think that something in the car's electronics is registering the voltage wrong. What sends the voltage reading to the DIC? I know there is a battery current sensor on the ground wire by the battery but is there a voltage sensor somewhere or is it in the ECM? Has anyone seen this before? Any suggestions? I have no electronic mods on the car, I am not using the HID kit, and I don't have any accessories installed.
    _____________________________________________
    '05 CompG - 3.6 Pulley, ZZP PCM, K&N drop in, Customized SD Headers, TEP Street/Strip tranny, ZZP STBs, ZZP Coilovers, GXP front brakes
  2. #2 Re: Volt gauge reading high, "charging system failure"
    check what voltages is coming out of the alt with it running, should be 14v~. There not built to run that high. Unplug the battery ground to reset the system. what year car is it? the 05 in you sig?
    SMGPFC Member #10
  3. #3 Re: Volt gauge reading high, "charging system failure"
    inside the alt is a voltage regulator, it maybe bad.
    seems its still charging properly tho, being 12 off, and 14 running. those are good numbers.
  4. #4 Re: Volt gauge reading high, "charging system failure"
    Williamsburg, Ky
    Yes it is my 05, everything looks good on my multimeter, it is just that the readout on the DIC is reading high and giving a failure. The actual voltage is good. I tried unhooking the battery, it made no difference.
  5. #5 Re: Volt gauge reading high, "charging system failure"
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    how long did you take battery off for
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  6. #6 Re: Volt gauge reading high, "charging system failure"
    Yoga city
    Have you re router the clamp near the battery terminals?
  7. #7 Re: Volt gauge reading high, "charging system failure"
    Williamsburg, Ky
    I took the battery off for roughly 30 mins. New information though, there is a small black wire with a white tracer connected to the negative battery lead with a connector just below the current sensor. The wire in question is not connected to the current sensor, it just goes through it. If I disconnect that wire the voltage reading goes back to normal but it gives a service vehicle light. Does anyone know what that wire goes to?
  8. #8 Re: Volt gauge reading high, "charging system failure"
    pic of said wire would really help out.
  9. #9 Re: Volt gauge reading high, "charging system failure"
    Williamsburg, Ky
    It got dark on me, I'll try to get one tomorrow if it isn't pouring rain. There are only 3 wires on the negative battery terminal, the other two are heavy gauge, this one is small like an 18 gauge and it disappears into the wiring harness just after the connector I mentioned.
  10. #10 Re: Volt gauge reading high, "charging system failure"
    Williamsburg, Ky
    After some research I found out that the wire is a ground lead directly to the BCM. Everything is pointing to a bad BCM. Anyone have experience with this and know what all is involved? Will I have to get it programmed by a dealer?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Have you tried a different DIC. Have you checked the voltage at the DIC plug? I can go bring up a diagram real quick.
    To your other question yes a new bcm must be programmed with a tech2. A used bcm will not work. (vin locked, and also can have option configuration errors)
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
    Oct 2011
    MI
    Looks like it's data. Has a 12v source you could check voltage going in. A scanner like a tech2 could show what the bcm is seeing. The dic is either bad or the bcm is commanding those values. Any codes or weird lights coming on? Example abs or random dummy lights? Because at those voltages the car won't run. It actually be likely to see several bad modules caused by such a spike.
    I'd put money on a bad DIC but if the bcm is bad (which if it were you should see other weird things happening as well like no power door locks or lighting issues etc) Can you communicate with the bcm?.
    Edit that's for an 04. Let me check 05.. Okay Diagram shows the wiring is the same for the different years.
  13. #13 Re: Volt gauge reading high, "charging system failure"
    Williamsburg, Ky
    I went through the BCM harness and checked the 12v source wires and they all read okay. Reading the diagnostic info in eSI it says to check between the sources and their corresponding ground but it does not say which grounds correspond to which inputs. Anyone have any info on that? Also, there is a 12v reference lead that goes to the ignition switch from the bcm, I am confused about that circuit but I am guessing the car wouldn't be running if it was bad.
  14. #14 Re: Volt gauge reading high, "charging system failure"
    Feb 2009
    Chicago Suburbs
    Quote Originally Posted by Aeroheadcww View Post
    Sorry to bump an old thread but I'm having the identical issue as the OP. The car runs/starts fine and all electronics are fine. I am also getting this charging system failure issue on my 2005 Grand Prix GT. I've cleaned my battery terminals, checked voltage at battery and alternator, checked OBD II voltage and all checks out fine when off or even on a load. All of the local auto part stores say everything is fine with my battery and alternator. The battery was replaced a few years ago and the alternator is original.
    Just as the OP said, when I unplug this mystery black wire with a white line on it that comes right from the ground wires on the battery terminal, the voltage will read correct on the DIC but I get a service vehicle soon message. When I plug it back in, the voltage on the DIC shoots up to ~18-25 volts and says charging system failure. When checked with my DMM, it shows a proper 12.8-14.5 volts.
    I've been troubleshooting this for 2 weeks and want to figure it out. I am beyond stumped and want to get this taken care of. Any help or advice is appreciated!
  15. #15 Re: Volt gauge reading high, "charging system failure"
    Williamsburg, Ky
    This ended up being a bad BCM. I bought one on Amazon (http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1). The replacement part numbers were changed a few times but the final part number for mine was ACDelco 15942206, which was a generic replacement for many GM cars that has to be programmed by a dealer. I replaced it myself, and after you go through the security relearn procedure you can drive it to the dealer. My dealer charged around $80 for the reprogram, and the only issue I have with it is that the door locks cycle twice when you put the car in reverse instead of just locking like it is supposed to.
    The dealer told me that it was my alternator, and assured me of that. They were wrong, and I spent $200 on an alternator that I don't need. I am sure that they would have charged me a lot more and came up with the wrong diagnosis again and again if I had left it up to them. Beware of lazy mechanics, its hard to find one that will actually research and investigate an issue like this.
  16. #16 Re: Volt gauge reading high, "charging system failure"
    Feb 2009
    Chicago Suburbs
    First off, thanks for your reply as I've searched in many areas and you're the only one to have the same issues. That being said, did you change your BCM due to it being an annoying false alarm ot did you run into other issues? More recently, I'm getting the "service vehicle soon" error on my DIC. I only got this error before when I unplugged the small ground line near the battery. It seems to be an issue related to the ground either on the BCM or at the main location on the vehicle.
    How hard was it do pop the BCM in and re-learn? Any input is greatly appreciated as every mechanic has wrongly diagnosed it. Really trying to avoid the stealership.
  17. #17 Re: Volt gauge reading high, "charging system failure"
    Williamsburg, Ky
    Unfortunately you cant avoid the stealership on this one. The bcm has to be programmed to your car. I changed mine because i was having charging issues that showed up intermittantly. I had to jump the car off a couple of times. It was easy to change, its under the driver side dash. The security relearn you can do a quick search for, its no big deal. Expect tons of errors until you get it programmed.
  18. #18 Re: Volt gauge reading high, "charging system failure"
    Feb 2009
    Chicago Suburbs
    Thank again!
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  1. Charging System Failure
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-03-2013, 11:51 AM
  2. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  3. Charging system failure w/HID's
    By zx7r4u2nv in forum General Tech Discussion
    Last Post: 03-12-2011, 12:37 AM
  4. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  5. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
