Thread: Mysterious Squeak Location ***SOLVED***
Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
  1. #41
    I live here. DirtDog's Avatar
    Jun 2012
    How u not paying full price? And what makes u think the PS pump is going bad? Mine has always had a wine in it
    Sent from my DROID RAZR using Tapatalk 2
  2. #42 Re: Mysterious Squeak Location ***SOLVED***
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    Quote Originally Posted by marines542 View Post
    The guy that helped me with the tensioner is a licensed mechanic an he can get me discounted prices on parts The pulley pulls in an out a little bit, you turn the wheel all the way to the right, you can hear it loud an clear.
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
    Jun 2012
    O OK gotcha. Well should be pretty easy to replace
  4. #44 Re: Mysterious Squeak Location ***SOLVED***
    Jan 2012
    Sturgis, MI
    Yeah the tensioner didnt seem that bad. But yep, everything is taken care, thank you for taking part of all this.
    Miles: 170-XXX
    Engine: 3.8L V6
  5. #45 Re: Mysterious Squeak Location ***SOLVED***
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    a rule i live by, if a serp belt goes bad i replace the tensioner too. when one goes bad, the other is about the same
    good work, safe cruisin
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  6. #46 Re: Mysterious Squeak Location ***SOLVED***
    Jan 2012
    Sturgis, MI
    Quote Originally Posted by Seachicken View Post
    Hey thank you , yeah with the PSP being replaced, most likely gonna get a whole new belt because the 1 i have now has been taking a beating the past couple days, stretch an its just a little wore out so might as well.
    Miles: 170-XXX
    Engine: 3.8L V6
  7. #47 Re: Mysterious Squeak Location ***SOLVED***
    Jan 2013
    Edmonton, Alberta
    the belt you have now is low miles right.......
    if the ribs are not cracked leave it,
    its good
  8. #48 Re: Mysterious Squeak Location ***SOLVED***
    if the belt has no cracks and still has V groves in it. wash it in hot soapy water with a scrub brush. rinse it, then let it dry, put it back on. clean belts hold pulleys better.
    you can also wash the pulleys on the engine if they are dirty looking. the belt will produce dirty water.
  1. Mysterious dinging!?!?!
    By silverbullet10 in forum General Tech Discussion
    Last Post: 03-02-2014, 02:04 AM
  2. mysterious connector!?
    Last Post: 08-09-2011, 02:00 PM
  3. Mysterious grind only while braking
    By techweenie in forum Brakes/Suspension/Chassis
    Last Post: 06-20-2011, 07:06 PM
  4. Mysterious coolant loss ...
    By timweidner in forum General Tech Discussion
    Last Post: 03-13-2010, 09:33 AM
  5. mysterious clicking
    By bennybravo in forum General Tech Discussion
    Last Post: 03-06-2010, 01:07 PM
