Thread: Need help Finding A/C Leak
Results 1 to 6 of 6
  1. #1 Need help Finding A/C Leak
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Hi guys, 2001 GT with 3.8, a/c quit last summer. Compressor wasn't engaging, so I added 2 cans of 134a around August and it blew cold for about 2 weeks and then quit again. Now the compressor won't kick on, so telling me that the refrigerant is leaking out and the low pressure switch is doing its job by keeping the compressor off. Also telling me that the leak can't be huge if it took 2 weeks for the pressure to drop low enough to kick out the low pressure switch, and that everything is the system is working as long as I can keep refrigerant in it.
    Sooo...how do I start looking for the leak? Any known places where they "always" leak? I don't have that much experience with a/c repair so need some troubleshooting tips.
  2. #2 Re: Need help Finding A/C Leak
    St. Louis
    Well, you could refill the system and then spray some soapy water around all the connections/lines/etc and see if you get any bubbles.
    Best bet would be to take it to a shop and have them dye test it I would think.
  3. #3 Re: Need help Finding A/C Leak
    Chances are it's the compressor. You could put some uv dye in it and find it that way.
  4. #4 Re: Need help Finding A/C Leak
    Dec 2008
    ****'s Creek
    Ok thanks
  5. #5 Re: Need help Finding A/C Leak
    Dec 2008
    ****'s Creek
    Guys, see pic below. is this an a/c line? It runs from the radiator under and then somewhere.....it looks like it's leaking. Well I guess here's another way to ask the question: do GPs have power steering coolers? If not this is definitely an a/c line. Any what this called if I wanted to order one??
    This is on the drivers side, radiator would be on your right in this pic, big thing on the left is the exhaust crossover.
  6. #6 Re: Need help Finding A/C Leak
    wet one looks like a trans line.
  1. Need help in finding an oil leak!
    By charlie31603 in forum General Tech Discussion
    Last Post: 11-11-2012, 11:14 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. need help finding a CAI
    By Joshmoshh in forum General Grand Prix Discussion
    Last Post: 04-20-2012, 01:34 PM
  4. Help finding a coolant leak (pics)
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-18-2011, 08:37 PM
  5. need help finding coolant leak
    By smote in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-24-2011, 04:41 AM
