How u not paying full price? And what makes u think the PS pump is going bad? Mine has always had a wine in it
Sent from my DROID RAZR using Tapatalk 2
O OK gotcha. Well should be pretty easy to replace
Yeah the tensioner didnt seem that bad. But yep, everything is taken care, thank you for taking part of all this.
a rule i live by, if a serp belt goes bad i replace the tensioner too. when one goes bad, the other is about the same
good work, safe cruisin:D
the belt you have now is low miles right.......
if the ribs are not cracked leave it,
its good;)
if the belt has no cracks and still has V groves in it. wash it in hot soapy water with a scrub brush. rinse it, then let it dry, put it back on. clean belts hold pulleys better.
you can also wash the pulleys on the engine if they are dirty looking. the belt will produce dirty water.
