yea..... sorry if i came off as a dick. i know what your talkin about in regards to that speed shop. i feel most, if not all the shops here are like that. the quality of work is quite poor out here. So if you can trust a builder then by all means use him.
being here in canada if i got a part number, its usally cheaper for me to buy off summit and have it shipped here. very poor supply in westeren canada unless you own a diesel truck.
dont be shy to spend your money on machining, id rather have a low powered turd that will run for another 4000 hours then a hi perf engine that every bore is egg shaped and seems good untill your tenth hard pull only to leave you where you are now.
what compression you runing,, the n/a is 9.4 right??? the cam will help but your can tune might not be ideal
