Thread: Ignition Switch Won't Release Key 2001 GTP
Results 1 to 12 of 12
Comanche1959 Ignition Switch Won't Release... 12-31-2012, 10:13 PM
vandezand Re: Ignition Switch Won't... 12-31-2012, 11:06 PM
Comanche1959 Re: Ignition Switch Won't... 01-01-2013, 11:03 AM
nicks98gtp Re: Ignition Switch Won't... 01-02-2013, 11:51 PM
Comanche1959 Re: Ignition Switch Won't... 01-03-2013, 04:49 PM
philr roy Re: Ignition Switch Won't... 01-04-2013, 10:52 AM
Scottydoggs Re: Ignition Switch Won't... 01-04-2013, 11:09 AM
ronaldgtp Re: Ignition Switch Won't... 01-04-2013, 11:20 AM
philr roy Re: Ignition Switch Won't... 01-04-2013, 02:37 PM
philr roy Re: Ignition Switch Won't... 01-04-2013, 02:40 PM
Scottydoggs Re: Ignition Switch Won't... 01-04-2013, 03:05 PM
ronaldgtp Re: Ignition Switch Won't... 01-04-2013, 07:08 PM
  1. #1 Re: Ignition Switch Won't Release Key 2001 GTP
    Donating Users
    phila pa
    Hi have the same model and year. Under the shifter is a solenoid .the wires on the plug brake off. new connector standard part number s1699 or Delco pt3923 or pt 2266.also will no soon be able to take out of park. There is a release on the shift. Have to pop off the cover where is says pndr release look up.
  2. #2 Re: Ignition Switch Won't Release Key 2001 GTP
    Jan 2013
    canada
    Thanks Ronald but I need the number for the igntion lock solenoid, not the shift lock solenoid. the ign lock solenoid is in the steering column and has been covered before in this forum. cant find the part no to order it yet is all. Phil
  1. 2001 Grand Prix ignition switch position
    By davejt in forum General Tech Discussion
    Last Post: 06-15-2010, 11:07 PM
  2. Key stuck in ignition & shifter wont release!!
    By Pontiac 2003 in forum General Tech Discussion
    Last Post: 04-03-2010, 12:54 PM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  4. 2002 won't release key from ignition
    By BLOWN93LX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2009, 02:04 PM
