I just tried to install the alternator rewire from zzp, i bolted it on the back of the alternator and the top of the fuse box with the negative battery cable disconnected. once installed and battery hooked up, i went to pop the trunk with the switch on the door. When i pushed it over you could hear everything play thru the speakers (doors unlock, lock, and pop truck). i went and tried to start it and the battery was dead, just the relays clicking. Then the fog lights were flashing, so i took the rewire kit off and had to jump the car to start it. The battery is pretty new and never gave any problems and hasnt since i took the re wire off. what could this be?
thanks
