Thread: Ignition Switch Won't Release Key 2001 GTP
Results 1 to 12 of 12
  1. #1 Re: Ignition Switch Won't Release Key 2001 GTP
    GT Level Member nicks98gtp's Avatar
    michigan
    if your not to concerned about having it be original, what i did when mine went out was if you pull the trim off the sterring column, you will see a little plunger sticking down on the ignition cylinder when the car isnt in park. I fed a couple small zip ties up and around and got them to hold the plunger in all the time. Never had a problem with key not coing out again, however the key will come out when the gear lever is in any position. hope this helps you
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  2. #2 Re: Ignition Switch Won't Release Key 2001 GTP
    SE Level Member Comanche1959's Avatar
    Nov 2010
    Kentucky
    That's exactly what I did.
  3. #3 Re: Ignition Switch Won't Release Key 2001 GTP
    Jan 2013
    canada
    2002 gp se-Only problem is that soon our daughter will be driving this car. Worried she will leave the car in drive and it will roll away one day. Does anyone have the igntion lock solenoid part number?
    Also looking for a wiper control module part no as the intermittant function has failed.
  1. 2001 Grand Prix ignition switch position
    By davejt in forum General Tech Discussion
    Last Post: 06-15-2010, 11:07 PM
  2. Key stuck in ignition & shifter wont release!!
    By Pontiac 2003 in forum General Tech Discussion
    Last Post: 04-03-2010, 12:54 PM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  4. 2002 won't release key from ignition
    By BLOWN93LX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2009, 02:04 PM
