Thread: Cruise Control Problems
Results 1 to 6 of 6
DJFirestorm07 Cruise Control Problems 12-10-2008, 12:50 PM
SyntheticShield Re: Cruise Control Problems 12-10-2008, 01:19 PM
DJFirestorm07 Re: Cruise Control Problems 12-10-2008, 02:53 PM
SyntheticShield Re: Cruise Control Problems 12-10-2008, 03:44 PM
Zef_66 Re: Cruise Control Problems 12-11-2008, 09:21 AM
Smokin2000gtp Re: Cruise Control Problems 12-11-2008, 02:01 PM
  1. #1 Cruise Control Problems
    Nov 2008
    Fenton
    Hey guys and gals, yesterday, my cruise control on my 2004 pontiac grand prix went out. At first, i thought it was just a simple blown fuse, but after replacing it, it is still not working. Any ideas to what the problem is?
  2. #2 Re: Cruise Control Problems
    Oklahoma
    Check your third tail light, if its blown its been known to cause the cruise control to not work.
  3. #3 Re: Cruise Control Problems
    Nov 2008
    Fenton
    Just checked it....the 3rd tail light is working...cruise control still not working...
  4. #4 Re: Cruise Control Problems
    Oklahoma
    Im out of ideas then if you have cleared all the fuses. Hopefully someone else will pop in that has some other ideas.
  5. #5 Re: Cruise Control Problems
    PA
    Check to make sure the cable going from the cruise control module to the throttle linkage is connected. On my 97, this would often come unhooked because of the type of connection it is.
    But now that I think about it, might be totally different than your 04.
    2001 GSE
  6. #6 Re: Cruise Control Problems
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Mine went out a while ago too and from what I've read it could be a number of possibilities (like about 20 or so ), so I pretty much said screw it. The odd part is that it randomly started working again for me, so whatever. I'll try and find my original post cause there was a ton of things to check.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  1. Cruise control not enabling...
    By m0ng00se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-20-2009, 02:09 PM
  2. Cruise control cable keeps popping off...
    Last Post: 10-28-2008, 10:28 PM
  3. Vernon Texas Cruise
    By Red_GTP in forum Southwest
    Last Post: 08-07-2008, 07:34 AM
  4. Cruise Control stopped working
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 07-03-2008, 11:48 PM
  5. Cruise Control Light
    By Darkcelle in forum Off Topic Discussion
    Last Post: 06-12-2008, 06:13 AM
