Thread: GTP Shimmy During Acceleration
Results 1 to 8 of 8
tabor0284 GTP Shimmy During Acceleration 10-21-2012, 01:35 PM
dsmuts Re: GTP Shimmy During... 10-21-2012, 02:40 PM
Fivefingerdeathpunch Re: GTP Shimmy During... 10-21-2012, 07:41 PM
Sushamouf X3 had this problem when I... 10-21-2012, 07:47 PM
Steven Monteith Re: GTP Shimmy During... 10-22-2012, 12:16 AM
tabor0284 Re: GTP Shimmy During... 10-23-2012, 10:34 AM
Sushamouf CV joints can leak grease... 10-23-2012, 10:51 AM
Steven Monteith Re: GTP Shimmy During... 10-23-2012, 07:52 PM
  1. #1 GTP Shimmy During Acceleration
    Lansing, MI
    Ok guys just wondering if anyone has any ideas on this problem. My 2001 GTP shake or shimmies when I am accelerating to get on the highway. When I reach speed the shimmy goes away. The tires have been rotated and balanced numerous times with no change to the problem. Hoping for a bit of brain storming for things to check, or if anyone else has had this problem as well. Lets see what you got...
  2. #2 Re: GTP Shimmy During Acceleration
    Cv joint
  3. #3 Re: GTP Shimmy During Acceleration
    Agreed with the dood above.
    Axle is bad, might aswell do both.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    X3 had this problem when I bought mine, new axles fixed it.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  5. #5 Re: GTP Shimmy During Acceleration
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    Cv joint or possibly a motor mount or tranny mount since it only shakes when accelerating. Check all 3 motor mounts.
  6. #6 Re: GTP Shimmy During Acceleration
    Lansing, MI
    Thanks guys. Are there diagnostic steps/visual abnormalities to spot a bad CV joint, Axle, or Motor/Tranny Mounts? I really hope there are more ways than "a vibration during acceleration" to figure out if these parts are bad and in need of replacement.
    May 2011
    United States
    CV joints can leak grease from a ripped boot, and make a popping noise when cornering sharp. Mine looked perfect when they were shaking under acceleration though, so you might not be able to spot anything visually.
    Sent from my Droid
  8. #8 Re: GTP Shimmy During Acceleration
    May 2012
    Phoenix, AZ
    I've had a CV joint splatter black grease all over and another that looked completely fine, but replacing both solved the problem. Check the upper motor mounts and check for cracks. The lower motor mount which will be on the passenger side might be hydraulic so when those go bad they will crack and leak oil. Tranny mount will be cracked. better way is to stick a pry bar between the mount and bracket and see how much movement you get.
  1. help with high speed shimmy and clunk over bumps
    By accuab in forum Brakes/Suspension/Chassis
    Last Post: 02-14-2012, 07:28 AM
  2. Acceleration
    By Fivefingerdeathpunch in forum Off Topic Discussion
    Last Post: 09-25-2011, 11:18 PM
  3. New acceleration vid
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 11-29-2010, 01:58 PM
  4. 97 L36 Acceleration Problems
    By gpaddictiongtp9798 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2010, 11:20 PM
  5. Pop on acceleration
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2008, 07:07 AM
