Thread: Headlights on all the time.
Results 1 to 12 of 12
  1. #1 Headlights on all the time.
    Jul 2011
    Robert, La./Pensacola, Fl.
    Have a quick question. Anytime lately the headlight and tailights are on. The DRL part hasn't been working for about 3 years, but now the lights are on, almost like the twilight sensor has gone out. It's a 99 GT.
  2. #2 Re: Headlights on all the time.
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    its a super easy fix, go into the fuse box thats in your glove box and pull the fuse labled DRL problem solved!!
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    You can do that, but every once in awhile it might squeal at you.
    There is a heatsink behind the panel on the drivers side of the dash.
    Its covered by the door when the door is shut.
    I genuinely suck at explaining things... i know there is a writeup somewhere...
  4. #4 Re: Headlights on all the time.
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Quote Originally Posted by asite57 View Post
    Only probly is that they will not automatically turn on but I've been dealing with this for about 2 months and its not that bad.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  5. #5 Re: Headlights on all the time.
    Topeka, KS
    Mar 2012
    Minneapolis MN
    Quote Originally Posted by rynoman03 View Post
    Go here he has a writeup.
    thanks for that
    I'm on tapatalk so i couldnt really get to it.
  7. #7 Re: Headlights on all the time.
    Topeka, KS
    Gotcha. That guy is super knowledgeable on the GP wiring. I'm glad his website is still online after all this time.
  8. #8 Re: Headlights on all the time.
    Jul 2011
    My problem is the twilight feature is on continuously. Don't care that much on the DRL stuff.
  9. #9 Re: Headlights on all the time.
    Oct 2011
    Michigan
    if you pull the DRL fuse your headlight will be off all the time unless you turn the switch to turn them on
    automatic headlights a re the stupidest thing ever invented if your headlights are on during the day time you look like a women and your carr looks like trash
  10. #10 Re: Headlights on all the time.
    I think its illegal if your car is equiped with DRLs that you disable them but to be honest I know there are GPs that Ive seen from like 97 and 98 that dont have them so a cop probly wont hassle you for that. Someone will correct me if I messed up the years.
  11. #11 Re: Headlights on all the time.
    Topeka, KS
    Dude the photoconducter in the dash is the twilight. I know that first link has a link to that.
    Read dude... http://www.backinblackgp.com/DRL_TS_Kill.htm
    For the 1997 Grand Prix, you can quickly disable the automatic headlamps by replacing the photoresistor in the dash at the center base of the windshield with a fixed 470-Ohm resistor. —>
  12. #12 Re: Headlights on all the time.
    Oct 2011
    Michigan
    its not illegal to disable DRL its agenst GM company policy to disable a safety feature and they will not do it for you at the dealship unless you have a written letter from the CEO of GM saying they may disable that feature for you
  1. Long time owner/first time poster!
    By brez in forum Introductions/Noob Questions
    Last Post: 08-08-2011, 04:58 PM
  2. Long time reader, first time poster.
    By KeithGTP03 in forum Introductions/Noob Questions
    Last Post: 01-27-2011, 12:55 AM
  3. long time visitor first time poster
    By max98 in forum Introductions/Noob Questions
    Last Post: 05-20-2010, 10:50 PM
  4. Part time headlights, all the time
    By myzon26 in forum General Tech Discussion
    Last Post: 03-04-2010, 08:23 AM
  5. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
