Thread: Pop on acceleration
Results 1 to 9 of 9
  1. #1 Pop on acceleration
    Feb 2008
    Ever since I got my motor back together, I've been having a pop in (what feels like) my suspension upon acceleration. It only does it after I've come to a complete stop or if I hit the brakes hard while rolling, then accelerate again. I've checked and re-checked my cradle bolts and the strut mount bolts. Everything I took apart this last build was checked and re-torqued if needed. I've also noticed that the noise occurs when pulling into my driveway, which is at about a 30* angle from the road. What's left to make the sound? I am missing a spring isolator, but that's been gone for a while, now.
  2. #2 Re: Pop on acceleration
    Jul 2008
    Poteau Oklahoma
    so this started only after your rebuild?
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  3. #3 Re: Pop on acceleration
    Feb 2008
    That's correct. Before the rebuild, there was no notable suspension noise.
  4. #4 Re: Pop on acceleration
    Jul 2008
    Poteau Oklahoma
    I wish I could help from here, but that could be sooooo many things. strut spring out of cradle, axle, brakes, engine/trans mounts etc, If you need someone to help you listen and look I would be glad to head up there, my next day off is this friday. pm me if so.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  5. #5 Re: Pop on acceleration
    chi-town
    maybe the timing is just coincidence , sure sounds like a sway bar or sway bar link to me. good luck finding it.
  6. #6 Re: Pop on acceleration
    Feb 2008
    I was able to replicate it today. I stopped on an incline and set the p-brake, then gave it gas and it popped. When I let off and gassed it again, it popped again. I'm going to get someone to do that and I'll do a walk-around and see if I can narrow down what area the noise is coming from.
  7. #7 Re: Pop on acceleration
    Moore, Oklahoma
    Check the front bushing on the A-arms. I bet its shot. Happened to me...
    Shawn W. Larsen
  8. #8 Re: Pop on acceleration
    Feb 2008
    How would I go about replacing the bushing if that is my problem?
  9. #9 Re: Pop on acceleration
    Oklahoma
    I believe they have to be pressed out and back in. You can check with Farns, he's done it before I believe and has all the part numbers.
  1. Humming Noise During Acceleration
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 01-02-2010, 10:03 AM
  2. Replies: 6
    Last Post: 10-11-2008, 09:30 PM
  3. No Acceleration issue
    By BooGTS in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-10-2008, 08:16 AM
