Thread: performance shift and TCS
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: performance shift and TCS
    St. Louis Mo.
    Quote Originally Posted by 02gp40th View Post
    Oh really, does anyone know about this?
    Here is my Tech Tip How To on installing the Performance Switch on GP's that do not have it installed.
    http://www.grandprixforums.net/f73/a...shift-701.html
    I hope this helps ya! Also IF you have the GTP DIC, the one that has the Boost Gauge meter graphic on it, you will have the Performance Shift option inside of it. NOT all DICs have this. Only the ones with the Boost Gauge meter on it generally have it. I can not say for the rest.
    There are many options on how you may want your PS to work. ie Toggle Switch, Full time mode (grounded on permanently), or finding a used Shifter with the PS button in it. My write up helps you to get the PS working in your car, the way you engage it is upto you.
    James Shafer
    St. Louis MO
  2. #22 Re: performance shift and TCS
    Bastard Reptile's Avatar
    Kansas City, MO
    Don't forget that sometimes you have to turn the PS mode on with a tuner too. If it doesn't have the correct settings in the PCM then it won't work even with the knob.
  3. #23 Re: performance shift and TCS
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Out traction control is not a full out constant on system Only works up to 20 or 25 MPH after that it disabled until it is back at 20/25 mph.
    IT is nice in some spots but if you learn to drive most of the time it is better to have it off.
    I always drive with it off and pref shift on.
    Also pref shift in long run can be thought of a tranny saver. Why? Quicker shifts thus less stress // Heat on clutch packs. Why shift kits are so nice too.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #24 Re: performance shift and TCS
    St. Louis Mo.
    Quote Originally Posted by Reptile View Post
    That was in the write up at the bottom of the Tech Tip
    James Shafer
    St. Louis MO
  5. #25 Re: performance shift and TCS
    GT Level Member Davisgtp's Avatar
    Dec 2008
    Rockford, Illinois, United States
    I have a 2002 gtp and mine has the performance right on the shifter I even have a tuned PCM
  6. #26 Re: performance shift and TCS
    GT Level Member nutcase's Avatar
    Washington State
    the only beef i have w/ps is I have long steep hills here..you cant down shift fast enough to slow down. But if I'm highway driving..i leave it on. The PS is really hard on my brakes trying to slow the beast down.
    My car doesn't leak oil,
    It marks it's territory.
  7. #27 Re: performance shift and TCS
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    Quote Originally Posted by Toofastgs View Post
    I installed the ZZP Tc off module, automatically turns off the Tc on start up.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  8. #28 Re: performance shift and TCS
    SE Level Member Crave Energy's Avatar
    Oct 2008
    San Jose
    I've tested my MPG with and without Performance Shift on and it really is no different. However it is more fun to drive with it on, and it's better on the trans. so I leave it on all the time.
  9. #29 Re: performance shift and TCS
    Topeka, KS
    Quote Originally Posted by Crave Energy View Post
    x2 Here. You can really tell a diff when you go to pass someone and it's not on.
  10. #30 Re: performance shift and TCS
    Tulsa, Ok
    O and on Pref Shift on 01+ gtps.
    It is engaged at wot by the pcm.
    if you want to add a switch Pin #21 on one the pcm connectors if i remember right. Just needs to be grounded out and you have to add the wire as it is not there.
    98' GS - Sold
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. performance shift WTH?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 07-08-2008, 09:44 PM
  3. performance shift
    By Scott B in forum General Tech Discussion
    Last Post: 06-29-2008, 08:40 PM
  4. ?? about performance shift button
    By DesQ27 in forum Off Topic Discussion
    Last Post: 06-29-2008, 01:13 PM
  5. why did they get rid of the performance shift ?
    Last Post: 01-17-2008, 02:18 PM
