Thread: 04 gtp blower motor keeps runing even with car shut off
Results 1 to 4 of 4
  1. #1 04 gtp blower motor keeps runing even with car shut off
    Sep 2012
    ohio
    hi all.. ive been reading threw many posts and it seems there are alot of problems with the blower motors in these cars... however no one seems to have the same problem im having.. my girlfriend came home from work one after noon and shut her car off... the blower kept runing so i went to the fuse box and pulled fuses under the hood and on the drives side pannel... kept runing... so i unhooked the battery cable and called it a night.... i talked to a friend of mine and he said it might be the transitor.... so i replaced that and all was good.... the other morning it was colder out and she said she had the whipers on and the heater defroster on.. and when she got to work she parked and shut the car off and now the blower motor is back to runing all the time... does anyone know the fix for these things? i see that there is a tsb from gm GM Service Bulletin No.: 05-01-39-001A... any input would be great..
  2. #2 Re: 04 gtp blower motor keeps runing even with car shut off
    Apr 2011
    Houston,TX
    There is a capacitor kit that needs to be installed. In a tsb it was described that voltage spikes caused by the wiper motor cause a logic lock up in the transistor. This causes the blower to run constantly. Once it starts running constantly the transistor will need to be replaced AND the capacitor will need to be wired in to prevent the same failure from happening again
  3. #3 Re: 04 gtp blower motor keeps runing even with car shut off
    Sep 2012
    ohio
    is there any write up or diy for this? it sounds simple enuf. i juat wanna make sure i know what wire im installing it in
  4. #4 Re: 04 gtp blower motor keeps runing even with car shut off
    SE Level Member DCGTP's Avatar
    Charleston SC
    raising the dead here, but I'm also having this issue and would like to know where I can get this kit or if theres a how-to thread already up on this.
    Overkilled, AL605s, 180 T-stat, Cone Intake, Cross drilled & Slotted Rotors, f-body upgrade, poly upper mounts, shorter dog bones,
    factory nav, 2x12s in the trunk, interior LED swap, all 5000k HIDs, red halo's in upper grille, tinted tails and reverse lights, de-badged, XM to line in conversion
  1. need some help heater(blower)motor wont shut off
    By fastorange in forum Audio, Security & Visual Electronics
    Last Post: 10-28-2012, 11:49 AM
  2. Blower fan wont turn off with motor running , stops with motor off
    By bosull in forum Introductions/Noob Questions
    Last Post: 04-20-2012, 07:32 PM
  3. Heater Blower will not shut off
    By 2005GTP in forum General Tech Discussion
    Last Post: 02-26-2011, 08:12 AM
  4. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  5. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
