Thread: Need Someone With A Tech 2...
Results 1 to 7 of 7
  1. #1 Need Someone With A Tech 2...
    SE Level Member G8GTChick's Avatar
    Naperville, IL
    To program the BCM to make the tailights flash with factory keyless entry on my 00 GTP. Message me or reply here. Thanks!
  2. #2 Re: Need Someone With A Tech 2...
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    You don't need to re program, you can wire your park lights to flash when you press a button on your fob
    Sent from my iPhone
    2004 Grand Prix GTP 150,000 " The New Edition "
  3. #3 Re: Need Someone With A Tech 2...
    someone else did that and the car was all pissed off, lights stopped working, blinkers, nothing good can come of this mod. its not a factory option so the bcm re program wont work either.
  4. #4 Re: Need Someone With A Tech 2...
    Dec 2008
    Lawndale, CA
    Check the manual and try one of the programs. There was a design change in 00-03. My brother has an 03 but I can't remember if his tails flash or not. I know the headlights do.
  5. #5 Re: Need Someone With A Tech 2...
    Oct 2012
    Philadelphia
    I did it, and I didn't have any problems at all, I have so many spliced wires in my GT it's not even funny with the dic and the HUD lol but as long as you do it correctly and take your time you should be fine
  6. #6 Re: Need Someone With A Tech 2...
    Donating Users moddman's Avatar
    Midwest
    Quote Originally Posted by Bills1997GTP View Post
    Can u post some instructions on what wire to tap into on the taillights to flash? I know its the brown wire for parking lights but what other wire do we need for her car to make this happen. I knew it was possible thats why I said it was good to ask on here. We would appreciate it to be sure on the correct way to splice them.
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  7. #7 Re: Need Someone With A Tech 2...
    Midwest
    Found it......----->>>w*w.gp-owners(dot)com/upgrades/rearlite/
    3.4" ZZP MPS Pull
  1. 04 GTP From MA. GM Tech.
    By Ricky Bobby in forum Introductions/Noob Questions
    Last Post: 04-28-2012, 06:11 PM
  2. Gm tech 2
    By 04intimidatorSS in forum General Tech Discussion
    Last Post: 03-30-2010, 07:08 PM
  3. Meguiars Tech Wax Ftw
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 08-16-2009, 07:56 AM
  4. Tech Question
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 02-22-2009, 03:12 AM
