Thread: ECU fuse
Results 1 to 7 of 7
  1. #1 ECU fuse
    Oct 2013
    RI
    I have a 99 grand prix. It had a mass air flow sensor code so I replaced the sensor. It went off for a few days then came back on with the same code. The connector was loose so I replaced that and it went off for a few more days. I have an apt to get it inspected today and the check engine light came on as I was pulling into work. I have herd that you can pull the ECU fuse and kill the codes so it will pass with out losing all its memory like it would if you un hooked the battery. I cant find the fuse for starters and does anyone know if it will pass an inspection if I do that. Im not sure if it has to go through all the drive cycles first.
  2. #2 Re: ECU fuse
    If you removed power from the PCM, the codes would be cleared and all your emissions would not be ready.
  3. #3 Re: ECU fuse
    Oct 2013
    RI
    That is what I thought too but someone was being pushy saying it would work.
  4. #4 Re: ECU fuse
    Oct 2013
    RI
    Has anyone had this problem and found a way to fix it? idk what else it could possibly be.
  5. #5 Re: ECU fuse
    check the wires to the maf's plug, look for cracks or missing insulation, if the wires are damaged in any way it car cause the maf code to pop up.
    if you do need a new pig tail, make sure you solder the new one on or the same problems will happen again down the road.
    what code are you getting? the one that says low voltage?
  6. #6 Re: ECU fuse
    Oct 2013
    RI
    I haven't checked it again since i got to work i am going on my lunch to have it checked. Im 90% sure its the same code. It was the only one it had before.
  7. #7 Re: ECU fuse
    if it comes back as the low voltage one, check the wires good. open the wire loom all the way to the fat part of the harness.
    my wires were also bad, i had to to keep stripping the wires to about 2 inches form the main harness. when you strip the insulation off the copper wire has to be clean and shinny, if its dull looking keep stripping till it shines. dull wire is dead wire, aka dry wire. currant cant flow properly through it.
  1. Fuse tap for wiper fuse.
    By Stormhaven in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2013, 12:24 PM
  2. looking for fuse box for 97 GTP
    By hammerbuilt in forum General Tech Discussion
    Last Post: 07-28-2009, 03:31 PM
  3. Fuse Box
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 06:10 PM
  4. Big 3 fuse
    By c32k05 in forum Audio, Security & Visual Electronics
    Last Post: 04-21-2009, 02:06 PM
