Thread: Knock sensors...
Results 1 to 8 of 8
JKICK6 Knock sensors... 09-25-2012, 12:52 AM
gtpeddie Re: Knock sensors... 09-25-2012, 12:57 AM
JKICK6 Re: Knock sensors... 09-25-2012, 01:09 AM
BillBoost37 Re: Knock sensors... 09-25-2012, 05:28 AM
00grandprixgtp Re: Knock sensors... 09-25-2012, 08:03 AM
JKICK6 Re: Knock sensors... 09-25-2012, 08:33 PM
Fivefingerdeathpunch Re: Knock sensors... 09-25-2012, 10:43 PM
MoarkatsINmuhtrailer Yes you can cam, been done... 09-25-2012, 11:07 PM
  1. #1 Knock sensors...
    Sep 2012
    FLORIDA
    I bought a motor from advance auto parts about 2 weeks ago.Motor has a slight ticking/knock/ping.I could not get the old knock sensors out of old motor so i proceeded to install new motor until i could afford 2 brand new knock sensors.Could motor be pinging because of not having either knock sensors hooked up?Car is not a daily driver.anyone have similar problems/experience with knock sensors on a 3800 series II .CAR IS A CHEVY MONTE CARLO SS
  2. #2 Re: Knock sensors...
    Jan 2012
    Philadelphia
    advance auto parts sells engines? (not to be off topic)
  3. #3 Re: Knock sensors...
    Sep 2012
    FLORIDA
    Yes through a company called ATK/SPARTAN.ENGINE WAS $1749.00 "LONG BLOCK"
  4. #4 Re: Knock sensors...
    You need knock sensors or you are going to have goofy programming running the car. I've never tried it out, but you'll either get a butt ton of timing or none I would assume.
  5. #5 Re: Knock sensors...
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    lol i wouldnt run it without knock sensors even a stock 3.8 can knock under a load
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  6. #6 Re: Knock sensors...
    Sep 2012
    FLORIDA
    Thanks guys.I ordered them this evening .They will be here in the morning.
  7. #7 Re: Knock sensors...
    Make sure you torque them to the right specs.
    And I dont think you can get at the rear knock sensor with the motor in the car, but I'm not 100% on that.
    Ohio
    Yes you can cam, been done plenty of times, you just can't see where you're grabbing lol
  1. Knock sensors enabled at what temp with overkill pcm.
    By mkyota1 in forum General Tech Discussion
    Last Post: 04-09-2012, 09:31 PM
  2. phantom KR without knock sensors
    By 97gpl36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2011, 04:57 PM
  3. 2001 Grand Prix GT - Knock Sensors
    By smlcrrll in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2011, 06:24 PM
  4. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  5. Knock Sensors Location 3800
    By MDThomas26 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2010, 12:23 PM
