Thread: Listen to the knock knock knock....
Results 1 to 19 of 19
  1. #1 Listen to the knock knock knock....
    Tofu Delivery Boy Lsick7's Avatar
    MO
    Have fun
    YouTube - GTP knocking like crazy
    Car will be rebuilt. Top swapped, s1x, 105s, etc
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  2. #2 Re: Listen to the knock knock knock....
    Never Never Land
    i shoulda took a video of my camaro before i took the motor out....picture taking two 3 pound hammers and just pounding the block like a mad man....thats what mine sounded like...cept it was worse lol
    have fun with the rebuild
  3. #3 Re: Listen to the knock knock knock....
    Can we drive it around and beat on it until it locks up?
  4. #4 Re: Listen to the knock knock knock....
    MO
    We should, but I'm afraid of any carnage screwing up the parts I want to salvage.
  5. #5 Re: Listen to the knock knock knock....
    Never Never Land
    thats what i shoulda done with the camaro lol....beat the piss out of it...shouldnt of took long...it had damn near no oil left in it
  6. #6 Re: Listen to the knock knock knock....
    sounds totally normal.
  7. #7 Re: Listen to the knock knock knock....
    MO
    Quote Originally Posted by That Canadian Guy View Post
    I kinda like it. The misfires make it sound cammed.
  8. #8 Re: Listen to the knock knock knock....
    That means i'm cammed?
  9. #9 Re: Listen to the knock knock knock....
    Never Never Land
    does indeed matt
  10. #10 Re: Listen to the knock knock knock....
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    How many miles on this motor? What is the suspected reason for failure?
  11. #11 Re: Listen to the knock knock knock....
    I live here. TLSheff's Avatar
    Sounds like mine was, spun bearing on cyl 1, cyl 2 was really loose. Still drove it to the apt and a couple startups and back to work
  12. #12 Re: Listen to the knock knock knock....
    MO
    Quote Originally Posted by mechguy View Post
    Mileage on motor was around 80k. I suspect spun bearing. Started showing white smoke a while back but no signs in oil, and virtually no coolant loss. Just started one day on the way home from school.
  13. #13 Re: Listen to the knock knock knock....
    Quote Originally Posted by Lsick7 View Post
    Odd... mine was at 83k, didn't notice until I got off the highway, was driving perfect and the sound of the tires and wind (windows were down) covered the sound of the knock
  14. #14 Re: Listen to the knock knock knock....
    MO
    ...double post. Stupid iPhone
  15. #15 Re: Listen to the knock knock knock....
    MO
    That is odd. Mine was running perfect then I got off the interstate and had the windows down. Thought I was hearing the sound of my drilled and slotted rotors as i braked as normal but it definitely wasn't. Pulled in the driveway and it's been parked since november.
  16. #16 Re: Listen to the knock knock knock....
    Dec 2010
    Canada
    ^^^^ The problem is likely a bearing, it would just be interesting to know what the cause is. If such can be found.
    Notice you said no coolant in oil, so that elimnates the most obvious potential cause.
  17. #17 Re: Listen to the knock knock knock....
    Odds are previous owners being fail at regular maintenance. Poor maintenance with hard driving tends to lead toward
  18. #18 Re: Listen to the knock knock knock....
    He got it from his cousin IIRC...and they just installed a new"er" motor...so idk there.
  19. #19 Re: Listen to the knock knock knock....
    Troy OH
    eewwww... it's like a kick in the nuts over and over again
  1. 00 GT rod knock
    By Sameyeam in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2010, 05:57 PM
  2. help with the knock please
    By BankRupt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 02:29 PM
  3. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  4. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
  5. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
