Thread: Knock sensors enabled at what temp with overkill pcm.
Results 1 to 8 of 8
  1. #1 Knock sensors enabled at what temp with overkill pcm.
    GT Level Member mkyota1's Avatar
    Daytona, florida
    Like the title says. Does anyone know at what temp Will at overkill has set the knock sensors to work at? When I am at the track I let the car cool way down between runs because it seems to reduce the knock I have. I want to make sure I have some protection from the knock sensors. I am seeing knock toward the top of second gear so I know they are working at least toward the end of the run.
    Im seeing around 5-6* when hot lapping and only around 1-2* when i let it cool off. Im only running a 3.6 pulley with headers, rockers, and cold air intake. Im working on a better tune but it looks like it is going to be close. Without pulling lots of timing its not going to get much better.
    Has anyone here actually done damage with a 3.6 on there car? Im sure i was knocking more with the stock pulley before the flow mods.
  2. #2 Re: Knock sensors enabled at what temp with overkill pcm.
    Ohio
    no 5-6* stock is about normal...depending where you are in the country.
  3. #3 Re: Knock sensors enabled at what temp with overkill pcm.
    Feb 2009
    flintnasty MI
    if the coolant temp threshold was not met, you would see 0KR. On some PCMs, the KR enable comes stock at around 170 degrees, so a 180 stat will sometimes hit that.
  4. #4 Re: Knock sensors enabled at what temp with overkill pcm.
    Daytona, florida
    Im sure it has been lowered. I will see if i can figure out what it is at now.
    Mercer, Pa
    Zzp told me years ago the enable there's at 100 degrees.
  6. #6 Re: Knock sensors enabled at what temp with overkill pcm.
    Daytona, florida
    That would be nice if it was around there. I bet its close.
  7. #7 Re: Knock sensors enabled at what temp with overkill pcm.
    104* F from a 4.2.
    Will left mine at 68* F in october of last year.
  8. #8 Re: Knock sensors enabled at what temp with overkill pcm.
    Daytona, florida
    Sweet man. That was just what i was looking for.
  1. phantom KR without knock sensors
    By 97gpl36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2011, 04:57 PM
  2. 2001 Grand Prix GT - Knock Sensors
    By smlcrrll in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2011, 06:24 PM
  3. Knock Sensors Location 3800
    By MDThomas26 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2010, 12:23 PM
  4. Part #s for temp,compass sensors
    By lilrez in forum 04+ Specifics
    Last Post: 04-13-2009, 12:42 AM
