Thread: Looking for help with adding fuses(the stock way)
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Looking for help with adding fuses(the stock way)
    Quote Originally Posted by glendayle View Post
    Scotty, that would be a prime use for the ignition drop down under the dash.
    ive yet to find that plug, i did see one all the way up by the dash, no idea whats its for, all alone unplugged lol but it was up there, by the solar sensor.
  2. #22 Re: Looking for help with adding fuses(the stock way)
    GT Level Member glendayle's Avatar
    Salt Lake City
    That's probably it. If you find the tape that is keeping it up there you can cut it and it will come down a little further. There is a sticker on it that says which wire is the ignition, battery, and the ground. You can order a plugin end from ZZP, but I just cut off the harness and wired up the wires with wire nuts.
    1999 Regal GS Mods-180 tstat; CAI FWI; ubend delete/3"DPCB PLOG; HID fog conversion, 3.5, tint(42%/20%), TK Trans 3.29 gears
  3. #23 Re: Looking for help with adding fuses(the stock way)
    ill stick a test light in it and see whats what, thanks.
    the wire from the fuse box still seems easier lol
  4. #24 Re: Looking for help with adding fuses(the stock way)
    Salt Lake City
    the drop down is super easy, but if you are wanting to run multiple things, I'd just as soon have it be separate.
    Salt Lake City
    Possible teaser.
    Sent from my SPH-D710 using Tapatalk 2
  6. #26 Re: Looking for help with adding fuses(the stock way)
    You need that to run your VCR? lol
  7. #27 Re: Looking for help with adding fuses(the stock way)
    Salt Lake City
    Maybe
  8. #28 Re: Looking for help with adding fuses(the stock way)
    Salt Lake City
    So while I was messing around I found this under the dash. Not the best picture, but it's a distribution block for my amps. It's fused. I decided in light of this I'm going to run a power line from this to the little Hella fuse box I bought. I'm going to put in a relay for switched ignition so it's not hot all the time.
    Put this together so I don't have to run 6 different relays/wires. I'll be running 10ga from the D-block to this with an inline relay. I'll likely be mounting this underneath the cup holder piece in between the shifter mounting stuff and the armrest cubby.
  1. 98 Regal GS thinking of keeping stock head unit and adding amp and subs??
    By jsnyder49090 in forum Audio, Security & Visual Electronics
    Last Post: 06-20-2012, 07:10 PM
  2. 2001 stock radio adding mp3 jack
    By 2001goldGTP in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2011, 03:17 PM
  3. Adding Mods to a stock car
    By FlipGTP in forum General Tech Discussion
    Last Post: 04-13-2010, 02:41 AM
  4. Adding Stock Foglamps
    By cue244 in forum General Tech Discussion
    Last Post: 09-16-2009, 12:33 PM
  5. NO CLUE: Adding AUX plug in for Ipod in stock bose stereo 2000 gp
    By sirpig34 in forum Audio, Security & Visual Electronics
    Last Post: 09-10-2009, 08:55 AM
