Thread: intermentant AC problem
Results 1 to 4 of 4
john breit intermentant AC problem 09-02-2012, 01:21 PM
Scottydoggs Re: intermentant AC problem 09-02-2012, 01:34 PM
john breit Re: intermentant AC problem 09-02-2012, 01:44 PM
00grandprixgtp Re: intermentant AC problem 09-02-2012, 01:37 PM
  1. #1 intermentant AC problem
    port charlotte fl.
    I have a 2000 GP and the AC will cut off for 1 or 2 seconds then turn back on. The air temp seem to be ok. I am not sure what I should look at first to try and figure out this intermentant problem.
  2. #2 Re: intermentant AC problem
    is it more like the fan motor quits?
    if so it could be the resistor for the fan, or the fan is on its way out. does the fan make any noise other then blowing air?
  3. #3 Re: intermentant AC problem
    port charlotte fl.
    no noticeable noise. Ihad replaced the resistor a few years back and at that time it showed the normal systems of failure. this just shuts down and back on in a second. havent been able to isolate fan or sustem because it happens so fast.
  4. #4 Re: intermentant AC problem
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    could be low or high head pressures aka freon might be lower or overfilled the condenser leak over on the driver side where the lines go in..
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  1. HID problem
    By dpzelenak in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2013, 12:21 PM
  2. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  3. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  4. Problem
    By mwillis in forum Introductions/Noob Questions
    Last Post: 10-05-2010, 03:54 PM
  5. DIC problem
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 04:41 PM
