Thread: LIM corrosion/pitting
Results 1 to 20 of 28
  1. #1 LIM corrosion/pitting
    May 2008
    I got my LIM off of my 2000 GTP and was cleaning it up and noticed that I have some pitting in the square section against the gasket between cylinders 2 and 4. When I removed it, it had a layer of coolant sludge just sitting on it. The port on the head that it sits against likewise had a nice thick layer of sludge.
    All of the other surfaces seem have some discoloration, but are smooth. Should I ignore it, or am I going to have to get a new LIM?
    Thanks,
    Steve
  2. #2 Re: LIM corrosion/pitting
    pics would help a lot.
  3. #3 Re: LIM corrosion/pitting
    May 2008
    I figured it would, but I was out, and couldn't attach at that time. Here are a couple pics.
  4. #4 Re: LIM corrosion/pitting
    It seems that some coolants over time eat away at the aluminum.
    A guy on here had the 2 coolant ports on his blower and on the LIM have pitting. Not to say its common, but it does happen.
  5. #5 Re: LIM corrosion/pitting
    Feb 2008
    A lack of cooling system maintenance can cause pitting in aluminum parts like that. Also, mixing Dex Cool and conventional green drastically reduces the anti-corrosive properties of the mixture. Make sure the system is flushed and always use the same type of coolant - no matter which one you choose to go with.
  6. #6 Re: LIM corrosion/pitting
    May 2008
    So what about the manifold though? Should I be good to put it back on given where the pitting is?
  7. #7 Re: LIM corrosion/pitting
    It's normal. Clean it better and put it back together like I would. I wouldn't even look at that twice.
  8. #8 Re: LIM corrosion/pitting
    May 2008
    Somewhat off topic, but I decided on short notice that since I was in there, I was going to do the lifters as well to get rid of the ticking. I forgot to get the bolts for the rocker arms, and pretty much no dealer around can get them until Monday.
    They're torque to yield bolts, so they have to be replaced, correct? Is there another option? I've seen some mention in other places of using non torque to yield bolts, that get torqued to 25ft/lbs, but I don't know where to get those.
  9. #9 Re: LIM corrosion/pitting
    Those would be like a Fastenall or McMaster type buy. All you need is the right thread, length in a non stretching bolt or recessed hex hed (most reusable bolts).
    Some have reused the rocker bolts w/o problem..a few have had them break. Honestly..it's likely not worth the issue, replace them. Maybe check with the parts places to see if anyone has them.
  10. #10 Re: LIM corrosion/pitting
    May 2008
    I haven't pulled the bolts yet. Do you know the specs for them?
  11. #11 Re: LIM corrosion/pitting
    If I knew..I'd have quoted them for you. I like to look like a know it all on Fridays. Sorry dude.. I don't have them. Check the bolt and bolt spec thread..I think it's in there.
  12. #12 Re: LIM corrosion/pitting
    May 2008
    I found the torque ratings, but nothing on the size. I'm just going to pull a bolt and take it to the Fastenal near me. Red loctite or blue when putting them back on?
  13. #13 Re: LIM corrosion/pitting
    None if you torque them to 25ft lbs like non stretching bolts.
  14. #14 Re: LIM corrosion/pitting
    May 2008
    3/8" head. 5/16" coarse X 2" o f course the fastenal near me didnt have any.
  15. #15 Re: LIM corrosion/pitting
    St. Louis
    How about a Lowe's or Home Depot? They usually have one of those thread matching guides near the bolt isle that you can use to thread your old bolt into to verify you have the right one.
  16. #16 Re: LIM corrosion/pitting
    May 2008
    Home Depot was a no go for the right size. Might try ACE later. The dealer can have them tomorrow morning though. Was hoping to get it all done tonight, but might just have to wait.
  17. #17 Re: LIM corrosion/pitting
    SE Level Member SMazza's Avatar
    Jun 2011
    Eastern Pennsylvania
    Quote Originally Posted by vertebrate View Post
    Are you sure it wasn't M8x1.25, with 10mm bolt heads, 50mm long? If you get it wrong, they are very close, but
    won't thread all the way in.
  18. #18 Re: LIM corrosion/pitting
    May 2008
    If that's what it's supposed to be officially, then I would go with that, and will delete my post above so that noone gets misinformed. What I had above is what they measured them as at the Fastenal store. I do know that the heads on mine are 3/8, as the 10mm socket had too much play.
  19. #19 Re: LIM corrosion/pitting
    May 2008
    I'm putting it all back together now, and looking at this Felpro kit that I got I have the runners that have the hard black plastic that sit on the edges of the block, but I also have two light blue grooved rubber pieces that are about the same length. I didn't take off anything that looked like them, and am wondering where exactly they are supposed to go?
    Are they for a different version of GP, or...?
    Thanks for all the help guys.
  20. #20 Re: LIM corrosion/pitting
    one is for na and one is for sc i believe.
  1. Pitting of aluminum parts
    By matt5112 in forum General Tech Discussion
    Last Post: 11-23-2010, 01:38 PM
  2. Corrosion on new timing sets? Plus advice on coolant elbows, LIM, AC, waterpump, etc
    By Scott Kane in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2010, 04:13 AM
  3. is this normal corrosion
    By millfire517 in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2009, 12:44 PM
  4. Pitting
    By GOINDEF in forum Tires & Wheels
    Last Post: 06-04-2008, 03:59 PM
  5. Diagnosing corrosion on coil pack terminals
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2008, 01:52 PM
