Thread: LIM corrosion/pitting
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: LIM corrosion/pitting
    Here's your answer.
    http://www.grandprixforums.net/lim-g...ign-39522.html
    Difference in the 96/97 blocks vs 98+
  2. #22 Re: LIM corrosion/pitting
    May 2008
    Thanks for the help everyone. I got everything back together, and aside from some cooling issues due to what seems to be a non-opening thermostat, everything is looking good.
  3. #23 Re: LIM corrosion/pitting
    You might have an air bubble. Once in a while you get a car taht doesn't want to burp out the air. Pull the t stat and fill the LIM through the stat hole..put it back together and likely you'll be all set.
  4. #24 Re: LIM corrosion/pitting
    May 2008
    yeah, I took the tstat out last night, and found that the lim coolant was about an 1-1.5" below the top of the coolant opening. I left the tstat out, filled it up, started the car, bled it and temp never got much above 185*. I filled the lim before I put everything back together the first time to help with getting the air out as well.
    I'm going to throw the tstat in a pot of water and see if it opens.
  5. #25 Re: LIM corrosion/pitting
    It seems that some coolants over time eat away at the aluminum.
    A guy on here had the 2 coolant ports on his blower and on the LIM have pitting. Not to say its common, but it does happen.
    Yeah, this guy.
    Hence looking into coolant and finding no answers.
    Dex doesn't provide any anti corrosion protection for the first 5-10 000 miles from what I've gathered.
    Try G-05 that can be found at Napa, less expensive than Dex around here yet instant protection.
  6. #26 Re: LIM corrosion/pitting
    May 2008
    I got the tstat in a pot and it turns out that it doesn't open until 210. Stock should open around 190, correct? Given how hot it is here I'm thinking of getting a 180. There shouldn't be any problem with that should there?
  7. #27 Re: LIM corrosion/pitting
    180 is ok. 195 should be stock.
  8. #28 Re: LIM corrosion/pitting
    You'll be fine with a 180
  1. Pitting of aluminum parts
    By matt5112 in forum General Tech Discussion
    Last Post: 11-23-2010, 01:38 PM
  2. Corrosion on new timing sets? Plus advice on coolant elbows, LIM, AC, waterpump, etc
    By Scott Kane in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2010, 04:13 AM
  3. is this normal corrosion
    By millfire517 in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2009, 12:44 PM
  4. Pitting
    By GOINDEF in forum Tires & Wheels
    Last Post: 06-04-2008, 03:59 PM
  5. Diagnosing corrosion on coil pack terminals
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2008, 01:52 PM
