most likely your pump is on its way out.
you notice if your leaking now that its full? p/s fluid dont burn like oil, if your low it had to leak out. so find leak, fix that as well. if the rack is leaking, you mind as well change the rack down the road too.
if need be, de grease your engine, then start looking for the leak.
pumps are 400+ dollars ouch
