Thread: whines when turning
Results 1 to 12 of 12
  1. #1 whines when turning
    GT Level Member RideWithPride's Avatar
    Oct 2011
    Whenever i turn, my car sort of whines, i ended up looking at my power steering reservoir (98 gtp) and according to the manual it is low on psf although i can see from a top view their is some fluid in their, my real question is, if i change my fluid do i have to go through the trouble of flushing my PSF or can i just fill it to full?
  2. #2 Re: whines when turning
    fill it and see if the problem go's away.
    If not, the pump may be shot.
  3. #3 Re: whines when turning
    Houston
    Fill it. These pumps get pissy when they get low.
  4. #4 Re: whines when turning
    Oct 2011
    forgot to ask is their any special power steering fluid that works really good with gtps?(98)
  5. #5 Re: whines when turning
    regular old power steering fluid works.
  6. #6 Re: whines when turning
    gardner,mass
    or atf, atf might help a little due to conditioners aswell if there is any ****ty gunk in there,and if there is a leak its easier to find
  7. #7 Re: whines when turning
    Oct 2011
    filled it up with some psf still makes the noise when i hit the gas turning
  8. #8 Re: whines when turning
    most likely your pump is on its way out.
    you notice if your leaking now that its full? p/s fluid dont burn like oil, if your low it had to leak out. so find leak, fix that as well. if the rack is leaking, you mind as well change the rack down the road too.
    if need be, de grease your engine, then start looking for the leak.
  9. #9 Re: whines when turning
    Oct 2011
    pumps are 400+ dollars ouch
    Dec 2010
    DMV
    Ps pumps? I got mines for like 70 bucks at the zone
  11. #11 Re: whines when turning
    pump is 70 ish, the rack cost some coin, up to 250 new, i got mine used for 75, but i have a friend so to say, most used are 100 to 150.
  12. #12 Re: whines when turning
    if your paying a shop to install your rack, then that price will climb up to 500 for the whole job, but an afternoon of your time can get it done for free. well free labor that is.
  1. Air bag not turning on
    By izup69 in forum 04+ Specifics
    Last Post: 03-13-2011, 05:56 AM
  2. Does transmission whines when is about to give up or need fluid??
    By Haulero in forum General Tech Discussion
    Last Post: 07-10-2010, 08:42 PM
  3. My intake sucks, my exhaust blows, and my car whines!
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2009, 09:13 AM
  4. help transmission whines and slips
    By joswo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-16-2009, 01:48 AM
  5. Trany whines....I think
    By evlprx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-17-2008, 01:14 PM
