Thread: PLEASE HELP: Coolant leaked out when removing throttle body
Results 1 to 5 of 5
  1. #1 PLEASE HELP: Coolant leaked out when removing throttle body
    GT Level Member RideWithPride's Avatar
    Oct 2011
    Today i had a freind help take off my throttle body so we could clean it out and when he reomved the tb coolant leaked out and on the engine, the tb gasket was broken, is this supposed to happen?
    my question is will this hurt my engine/ what should i do about it?
  2. #2 Re: PLEASE HELP: Coolant leaked out when removing throttle body
    Jul 2011
    NW Ohio, USA
    I do know that there are coolant passages going through the TB, I'd guess that the coolant that leaked out came from the coolant passages.
    Personally, I would replace the gasket either way. I don't think it could hurt.
    I Gotz Moar Powar Than U Gotz
    The HWG Thread = Winning.
  3. #3 Re: PLEASE HELP: Coolant leaked out when removing throttle body
    Oct 2011
    Quote Originally Posted by 98L36 View Post
    I really hope not and yes im getting a new gasket im curious if their is aluminum ones or are the reb tb gaskets just as good cuz this engine is rebuilt on its first 350+ miles
  4. #4 Re: PLEASE HELP: Coolant leaked out when removing throttle body
    yes coolant will come out when you take off the TB, get a new gasket, make sure both side are clean. re install. top off coolant, bleed the system, done.
    also remove your maf before cleaning the TB, you dont want anything but maf cleaner to get on the maf, or it will die on you.
  5. #5 Re: PLEASE HELP: Coolant leaked out when removing throttle body
    SE Level Member Nathan07GP's Avatar
    Mar 2012
    San antonio
    You will be fine thats normal when you remove your throttle body. I worried about the first time too it happen to me but yea like scottydoggs said, just clean it up so you wont have that nasty smell coming from under your hood, replace gasket top it off and bleed if of any air
  1. Coolant leak from Throttle body
    By jakegsxr11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-05-2022, 07:48 AM
  2. Removing throttle body studs
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-17-2010, 11:47 PM
  3. Throttle Body Spacer/Coolant Flow
    By TeeWX in forum General Tech Discussion
    Last Post: 03-26-2010, 12:38 PM
  4. removing throttle body?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2009, 01:29 PM
  5. i make wa baypass for the coolant to the throttle body opinions
    By gpracing in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-06-2008, 11:22 PM
