Thread: cleaning the engine..
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: cleaning the engine..
    GT Level Member Mikey Bonefas's Avatar
    May 2012
    Waterloo, IA
    ok cool, thanks man.
    hopefully tomorrow i can pick those up.
    easy job to do?
  2. #22 Re: cleaning the engine..
    Since you have a 97, yes.
  3. #23 Re: cleaning the engine..
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    yeah shouldent be too bad, if you were closer to cr i could help out lol
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  4. #24 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    well hell, id through yu some gas money haha.
    not to many guys i know that work on cars,
    let alone the 3800s.
    be kinda nice having someone with experience help out.
  5. #25 Re: cleaning the engine..
    Dec 2008
    Cedar Rapids, IA
    i wouldent have time till next weekend though, but if you end up waiting till then hit me up.
  6. #26 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    well im sure i could wait.
    i work all week and have weekends off.
    and the car works well enough to travel to and from work, so im sure i could wait.
    and maybe you can help me figure out what else is wrong with it, drives weird. but im thinking tie rods.
    ill just wait till next weekend though. not to far away.
  7. #27 Re: cleaning the engine..
    Dec 2008
    Cedar Rapids, IA
    alright
  8. #28 Re: cleaning the engine..
    Jun 2012
    Kansas
    Just a heads up I do not know if your car is under a recall but my 99 3800 is under a recall for oil dripping on the exhaust manifold and causing a fire. I just found out about the recall and my car did catch on fire and I got the vehicle fixed to the point I can drive it for now. I called gm about it and they told me that since I lived in Kansas any claims past 10 years of manufacture they will not cover since the recall came out just recently. So I would say check with your dealer about the recall and see if yours is under any, because if anything happens gm will not cover anything for u
  9. #29 Re: cleaning the engine..
    Quote Originally Posted by Angelo1912 View Post
    pretty sure the recall is only for the s/c engines. and your fire probably started due to a fuel rail leak.
    if it caught fire due to a oil leak, that means you ignored it way to long. if you had no oil leaks, then it was the leaky fuel rail.
  10. #30 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    haha, didnt buy from a dealer. and if anything im just going to end rebuilding the motor.
    new gaskets, clean the heads, maybe new pistons if they arnt bad, fuel injectors,
    and maybe a couple more things. but thats later on in the year or 2.
    so far no problem with it catching fire, neither with my old 97 se i had.
    only got rid of that because my rear strut towers blew out.
    if anything GM should fix that issue with all the wbody cars.
    thats all imo. the 97 GT i got now is having the same problem
    but im taking it to a shop to get fixed in a cpl weeks or so hopefully.
  11. #31 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    but how would i find out without going to a dealership? jus curious.
  12. #32 Re: cleaning the engine..
    Rebuilding a 3800 is a waste of money when perfectly good used engines are plentiful and relatively inexpensive.
    Call dealer with your VIN and ask.
    And GM should kill the W body once and for all.
    Its from the mid 80's, it needs to die.
  13. #33 Re: cleaning the engine..
    Jun 2012
    Kansas
    The recall is from a oil leak I have already checked with the dealer. Give your vin number. The recall was not for the super charged but the non supercharged motor
  14. #34 Re: cleaning the engine..
    For SC they replace spark wire retainers and front valve cover gasket.
    For NA they replace spark plug retainers.
    Solution is new fuel disconnects as well as valve cover gaskets and grommets.
    Might as well do the LIM, coolant elbows, and UIM (if L36) while you're in there.
  15. #35 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    haha, damn. already did my coolant elbows -_-
  16. #36 Re: cleaning the engine..
    GT Level Member GMCustomerService's Avatar
    Michigan
    Mikey Bonefas,
    If you would like, PM me the last 8-digits of your VIN and I can look up recall information for you.
    I look forward to your reply.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  1. engine bay cleaning
    By dlk in forum Detailing Tips and Tricks
    Last Post: 04-29-2012, 10:27 AM
  2. Cleaning Engine Bay
    By SupaCharg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2012, 03:20 PM
  3. engine cleaning
    By busagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2010, 08:53 PM
  4. Cleaning up engine
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 09-25-2008, 03:26 PM
  5. Cleaning Engine Bay
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 08-19-2008, 01:42 AM
