Thread: cleaning the engine..
Results 1 to 20 of 36
  1. #1 cleaning the engine..
    GT Level Member Mikey Bonefas's Avatar
    May 2012
    Waterloo, IA
    ok, so i have never had to wash a motor.
    my car has some oil caked on around the front of it above the headers and below the valve cover.
    just curious if it would hurt anything to take it to the local car wash and spray it off?
    because im not sure if its a leak or if it was a leak awhile back.
    im not losing any oil, check regularly, and i hate driving around with smoke rolling out from under my hood.
    any suggestions would be helpful.
  2. #2 Re: cleaning the engine..
    go get 2 cans of engine de greaser from the parts store, and then go to the car wash, spray down the whole engine, top and bottom as much as you can, follow the wait time and then spray it down.
    if your all stock you CAN HOSE the whole engine down. just dont blast the alternator.
    if you have a open cone, take it off and tape a bag over the TB.
  3. #3 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    ok thanks, tried looking for someone with the same issue as im having on here, but no luck.
    bone stock, so far anyways.
    would it be best to wash with the motor running?
    iv seen some videos on youtube where they have it running.
    not sure if that would be best or not.
  4. #4 Re: cleaning the engine..
    dont clean it while its running. let it cool off some before spraying it down with cleaner, wait 15 minutes or what ever the can says and wash it down.
    then start up and let it warm back up to dry it some.
    i used CRC engine degreaser, and there was like no smell when i was done, un like foamy engine brite cleaner.
    and the CRC worked real good, as good if not better than foamy engine brite.
    if your caked up thick around the front valve cover like you said, you may have to scrape it off some then clean it.
    after its all cleaned up you know if your leaking oil or not.
  5. #5 Re: cleaning the engine..
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    mikey what issue are you having? valve cover "wheepers" are very common.
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  6. #6 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    not really sure.
    got oil chillin right by the exhaust under the valve cover.
    im not loosing any. check it regularly and im still good.
    i just hate driving around and having my car smell like it could catch fire.
  7. #7 Re: cleaning the engine..
    Dec 2008
    Cedar Rapids, IA
    sounds like a wheeper
  8. #8 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    what needs to be done so itll stop weepin?
  9. #9 Re: cleaning the engine..
    Dec 2008
    Cedar Rapids, IA
    change the valve cover gaskets
  10. #10 Re: cleaning the engine..
    yup new v/c gaskets are in order. thats the only place oil can come from in that area.
    and defiantly clean the engine first, then to the gaskets.
  11. #11 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    mk, sounds like i got what i need to do now. thanks guys.
    what gasket would you guys recommend though? maybe link me to a site?
  12. #12 Re: cleaning the engine..
    felpro are good, get a set that has new gromits included.
  13. #13 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    ok, thanks for the advice. ill have to pick them up tomorrow.
  14. #14 Re: cleaning the engine..
    Dec 2008
    Cedar Rapids, IA
    ya i second felpro, its a pretty easy job to do
  15. #15 Re: cleaning the engine..
    May 2012
    Waterloo, IA
  16. #16 Re: cleaning the engine..
    Are you buying gaskets for a SBC or a 3800?
    Also sig wayyyyyyyyy too tall.
  17. #17 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    3800 n/a.
    and thanks. will make it shorter.
    720/200 work?
  18. #18 Re: cleaning the engine..
    Buy the second gasket, and thats fine, thanks guy.
  19. #19 Re: cleaning the engine..
    May 2012
    Waterloo, IA
    that one comes without grommets..
    i was told to get one with.. hmm
    so the cheaper felpro ones should fix my problem?
  20. #20 Re: cleaning the engine..
    Most places stock the NA gaskets separately from the grommets.
    For the SC gaskets they typically only come with the grommets.
    The more expensive gasket looks like its for a gen 1 small block chevy.
    Not exactly what you need.
    You want this: Buy Felpro Valve Cover Gasket Set VS 50080 R at Advance Auto Parts
    and this: Buy Felpro Grommet Set ES 72833 at Advance Auto Parts
  1. engine bay cleaning
    By dlk in forum Detailing Tips and Tricks
    Last Post: 04-29-2012, 10:27 AM
  2. Cleaning Engine Bay
    By SupaCharg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2012, 03:20 PM
  3. engine cleaning
    By busagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2010, 08:53 PM
  4. Cleaning up engine
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 09-25-2008, 03:26 PM
  5. Cleaning Engine Bay
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 08-19-2008, 01:42 AM
