Quote Originally Posted by Angelo1912 View Post
Just a heads up I do not know if your car is under a recall but my 99 3800 is under a recall for oil dripping on the exhaust manifold and causing a fire. I just found out about the recall and my car did catch on fire and I got the vehicle fixed to the point I can drive it for now. I called gm about it and they told me that since I lived in Kansas any claims past 10 years of manufacture they will not cover since the recall came out just recently. So I would say check with your dealer about the recall and see if yours is under any, because if anything happens gm will not cover anything for u
pretty sure the recall is only for the s/c engines. and your fire probably started due to a fuel rail leak.
if it caught fire due to a oil leak, that means you ignored it way to long. if you had no oil leaks, then it was the leaky fuel rail.
