I haven't driven my car for a year and recently transplanted the engine into a new body. I'm pretty sure before the car was running fine. Long story why I haven't driven for a year. Lady was passing a car going up a hill, I was on the other side coming over on my motorbike. She hit me head on and I lost my leg. So over the past 6 months, I've been rebuilding a car from the bottom -> up keeping busy
P0171. Pegged STFT and LTFT
Engine specs
T66 turbo with 3" downpipe
Lt1 MAF with min-afc set to 82%
HV3
#130 springs
ST5 cam
2 fuel pumps
#80 injectors
PCV system with catch can & smog pump. (I have this capped off until I can find out why my the car is lean, before i introduce more unmetered air into my intake)
First I replaced my egr stove pipe with a good one I had laying around while the engine was out. Once I pressurized my intake and used soap and water, found the second one is cracked at the seal too. So I RTV and put in a penny to close it up for good. No more EGR to worry about leaking. Also closed up the egr at the exhaust side but left everything in for emission checking. The motor is still plugged in, so no codes set.
I put in 10psi into the intake from a vacuum hose and it holds and slowly goes down. I'm confident it's not a vac leak on how slow it drops down to zero (but i've been known to be wrong sometimes). I can take a video of my gauge if I think it's slow, some may not. If I remember correctly from an hour ago, 5 seconds to drop to 5psi then maybe another 8-9 seconds to drop close to zero.
IAC counts are 35 at warm idle. (I've read 40 is normal, but I do have an aggressive cam). It will increase if I rev the rpm, and come back down to 35 at idle.
-12 psi vacuum at idle
Fuel pressure is 44 at idle, 52 with fpr pulled. I do notice the system doesn't hold a pressure, when turning the key to 'on', the system will pressurize and my aeroforce gauge will go back to zero as soon as the pump stops priming. Don’t think this is an issue causing me to go lean because it runs at idle fine. Just takes a few cranks to get it going, something to do with my dual aftermarket pumps. Again, I don’t think it’s an issue for this right now.
When I unplug the MAF, the STFT will go into the negative and the LTFT will starts to come down. The car will surge and eventually die after 10 seconds or so. I’ve cleaned the maf with electrical cleaner and special q-tips for electronics.
I've done the big 3 upgrade, so I don't think it's a grounding issue. Tomorrow I’m going to disconnect my big 3 and play around with the grounds, maybe too many is bad somehow.. ?
I'm puzzled.
Thanks everyone.
