First of all, apologies if this was addressed in another thread. I looked at several of the other posts about A/C not working but none exactly match my problem.
Let's start with some basic info. I have a 2001 GTP. It has dual climate controls. This setup, http://images.gtcarlot.com/pictures/54589586.jpg different stereo, not important.
When I press the A/C button the light comes on and that is it. It just blows the same temp air as if the A/C were off. All my fan speeds work, heat is also just fine.
In my 3.8 Monte Carlo when the A/C is turned on I can feel the 'performance' of the engine drop a bit, also the sound is different. With my GP I am not having either of those things happen, the car runs and sounds the same.
I have checked and it appears that all wires are connected and nothing looks physically damaged. (I had the SC idler pulley melt and apparently explode and take out the belt.)
I have not checked the pressure, but because literally nothing happens when it is turned on I assume it is mechanical.
So, from my reading of other posts on similar problems, many are caused by the A/C clutch. Does it sound like mine is bad too?
