Thread: DIC troubleshooting
Results 1 to 20 of 26
  1. #1 DIC troubleshooting
    GT Level Member skidoojames151's Avatar
    seattle
    so i have a 1999 GP SE. It has the 3.8 so i assumed it has the same computer as a GT. So I installed a digital DIC and everything works and lights up but my trip computer/oil life flash 0% and i get no data to it. Wiring has been double checked so its not that. Is it possible that my ecu isnt sending the proper data to the DIC? And would a intense/overkill pcm solve my problem?
  2. #2 Re: DIC troubleshooting
    seattle
    anyone have any knowlege on the topic?
  3. #3 Re: DIC troubleshooting
    GTP Level Member SuperSport's Avatar
    Michigan
    I would imagine it has something to do with the VSS connection or the DATA connection.
    1997-2003 Grand Prix Analog to Digital DIC Conversion - Automotive Forums .com Car Chat
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  4. #4 Re: DIC troubleshooting
    seattle
    i know that these two connections are good and correct...which is why i am confused...are there any other wires that would cause it to flash 0%?
  5. #5 Re: DIC troubleshooting
    Wausau, WI
    can you switch it off of the 0%......is this what is displayed for the oil life meter? Can you reset it? press and hold reset for ten or more seconds to reset...........I doubt an aftermarket tune would have anything to do with this.......not 100% sure though on anything.......if that does not work, disconnect the power to the car at the battery to reset cpu and see what happens.............keep us posted
  6. #6 Re: DIC troubleshooting
    seattle
    well the thing is is it displays 0% for all the modes (oil, range, fuel used etc.) which leads me to believe that im not getting a signal from either the DLC or the wire from the gauge. The other thing that i havent gotten to work correctly is the dimmer doesnt work so at night it is suuper bright..so obviously i have some wiring issues there...but im almost 100% positive on my DLC (tan wire on obdII plug) and my speed sensor wire (dark green on back of gauges)....another thing i might add is it has the check tire pressure light which i thought was only supposed to be on 1997's but the guy i got it from had a 2000 (i have a 1999)
  7. #7 Re: DIC troubleshooting
    Wausau, WI
    I would reset all power just to see if it is "locked up" now...........other than that I don't know much about the wiring of these. Sorry I can't be of more help.
  8. #8 Re: DIC troubleshooting
    seattle
    yea i will try that...thanks
  9. #9 Re: DIC troubleshooting
    Donating Users kind153's Avatar
    Pittsburg, KS
    Any solution yet? I have the same symptom!
  10. #10 Re: DIC troubleshooting
    seattle
    nope im still blinking 0.0 on all modes...all wiring is in check and im convinced that my car doesnt put out the correct data for the DIC to read and i figured out the dimmer issue...im just stumped on how to get this thing to work correctly
  11. #11 Re: DIC troubleshooting
    Pittsburg, KS
    .. That is a SAD news to hear!! Hope somebody can prove otherwise.
    How did you figure out the dimmer issue? I realized that the buttons(ENG, TRAC, etc.) aren't lit.
    I'm pretty sure my wires check.
    Do you have any idea what do a4, a8, and b10 do?
    (edit:
    a4: check tire pressure
    b10: fuel level input)
    What the heck is vf park ???
    ..so confused. Spent 5 hours and stuck on dreaded blinking 0.0!
  12. #12 Re: DIC troubleshooting
    Pittsburg, KS
    btw, you have a remote starter or have factory alarm system bypassed?
    Another possibilities I can think of...
  13. #13 Re: DIC troubleshooting
    Pittsburg, KS
    here's another one;
    Should HUD module be present in order to get DIC to work??
  14. #14 Re: DIC troubleshooting
    seattle
    im almost positive you dont need a HUD to have the DIC work...
  15. #15 Re: DIC troubleshooting
    GT Level Member tylerbinski's Avatar
    Canada
    there are like 3 different DICs
    you cannot use a 98 in a 97....
    also the 99-02 are different I believe...
    I have a 97, and I swapped the engine harness and PCM from a 98, my DIC stopped working (flashed 0) so i grabbed one from a 98, and it works now..
  16. #16 Re: DIC troubleshooting
    seattle
    alright then so that may be my problem..
  17. #17 Re: DIC troubleshooting
    Dec 2008
    Lawndale, CA
    Do you know what year the digital DIC came from? As stated only certain years work with each other. Also is this the digital DIC from a GT or a GTP? The only difference between the two is the traction button. Other than that they are identical.
  18. #18 Re: DIC troubleshooting
    germantown
    does anybody know why only the trac control and low trac button would work on my dic but not the display. checked all the bulbs behind the display and only one was bad so i replaced it but the display still doesn't light up. the previous owner stated that after technicians from Sears installed a new battery backwards possibly, and the display has not worked since then. is their any way i could check the dic wiring to the battery and make sure it is correct
  19. #19 Re: DIC troubleshooting
    Pittsburg, KS
    Hmm. That may be mine as well;
    ebay item description were its from 1999. Any way to check by just looking at DIC? like serial/part number?
  20. #20 Re: DIC troubleshooting
    Feb 2010
    O'Fallon MO
    subscribed
  1. Troubleshooting Help! 02 GTP - DIC/ AC Issue
    By Lawngoose in forum General Tech Discussion
    Last Post: 07-21-2010, 12:28 PM
  2. Troubleshooting: DIC Resetting/Flashing
    Last Post: 04-30-2009, 12:27 PM
  3. Transmission Whine Troubleshooting PLEASE HELP
    By rworkman98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-25-2008, 12:57 PM
  4. Troubleshooting Help! - A/C Problems
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 04:07 PM
