Most common problem with ac is loss of freon. Easiest thing to do is add can of freon with stop leak in it. Might work and you have cheap fix, might not and your out $10.
I'm having trouble with the AC in my 03 and hope it's ok to post here. My system has enough freon in it, but won't run. I sprayed the lines with a garden hose under the air box while cleaning the engine compartment, and the AC compressor kicks in and the system blows fairly cold air. The compressor will cycle a few times then will over pressure the system and I have to manually turn off the AC. Both cooling fans on the radiator also start and will run. Once I shut the system off and restart it it will run and cool if I hit it with the hose again. Ideas? hi/lo pressure switch is there too.......I'm miffed
