Thread: Window fog. How to get rid of?
Results 21 to 40 of 69
  1. #21 Re: Window fog. How to get rid of?
    Dec 2008
    Pennsylvania
    Do you ever smell that "sweet" smell that resembles antifreeze when you turn on any of your climate controls? What I have found to be the case more times than not in this case is that there is a small leak in the heater core and your "steam" you are seeing is vaporized coolant residue. It is VERY annoying. I would recommend removing the lower duct work panels and inspecting your heater core box to see if there is residue from coolant.
    I believe you will find your answer there...
  2. #22 Re: Window fog. How to get rid of?
    Jan 2009
    north dakota
    Quote Originally Posted by superjon78 View Post
    i was just about to say the same thing
  3. #23 Re: Window fog. How to get rid of?
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    i use eagle one glass cleaner and my windows never have streaks on them even if the windows fog up, still no visable streaks
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  4. #24 Re: Window fog. How to get rid of?
    Toronto
    ***EDITED***
    Please keep posts on topic. Thank you.
    Last edited by GeddyLee; 01-24-2009 at 02:30 PM. Reason: Post was off topic. Comment was unnecessary.
  5. #25 Re: Window fog. How to get rid of?
    I live here. UR LOSN's Avatar
    Rockford, IL
    I use Rain-X anit fog on the inside of my windows, and normal RainX on the outside. I never have a problem.
  6. #26 Re: Window fog. How to get rid of?
    Thunder bay,Ontario.Canada
    You should get to the root of the problem instead of putting a band aid on it. If you get instant total fogging look at your heater core. when you leave your drive way your motor and coolant are cold aswell as the thermostat is closed forcing it to bypass. Shortly after you leave your driveway the motor warms up, thermostat opens and sends full volume of water through the heater core which has a leak in it, this results in steam in the cabin with no where to go but onto your windows. or your heater intake water defector has come dislogded unknown to you allowing water onto the passenger side floor, under the carpet and mat.
    Sorry about the long post. hope this helps.
  7. #27 Re: Window fog. How to get rid of?
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    Lately with the cold weather, when I turn on my defroster all of my windows will fog up. Just started recently. We have been getting a lot of rain so I'm thinking the interior is damp and the car can't get rid of the moisture fast enough.. I hope its not the heater core.. where is that thread on replacing that drip shield?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Your AC removes the moisture from the vehicle and defogs the Windows. you don't have it on or it doesnt work. It does more then just make your car cold. Thus the reason your AC Compressor kicks on when selecting floor/windshield and windshield
    I'm very surprised Noone has explained this yet or mentioned it
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  9. #29 Re: Window fog. How to get rid of?
    Nov 2009
    chicago
    My Ac should work fine. Worked great all summer. I don't think its that, but I guess it could be. No way for me to tell if thats it since it 35degrees outside.
    I don't feel any water on the passenger side floorboard. Occasionaly I will get a musty smell, so maybe its leaking elsewhere.
    I do not have the re-circ button on so that shouldn't be it unless the damper is not opening. How can I tell if the damper is opening?
    I'm wondering if its the heater core, and will need to look closer.
  10. #30 Re: Window fog. How to get rid of?
    Nov 2009
    chicago
    I was thinking of trying BARS LEAK in my radiator to see if it will seal up any leaks I might have in my readiator core. If I have a leak.. What do you guys think? Which one should I use?
  11. #31 Re: Window fog. How to get rid of?
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    I suggest using a new heater core. I'm going through the same exact thing right now. Don't use any stop leak that stuff is only used for selling a sh*ty car. You can by pass the heater core. Get 3/4" heater hose and connect the inlet and outlet on your tensioner. If the fog goes away then you heater core is the problem.
    97 Bonneville SE Not so much a 97 anymore
  12. #32 Re: Window fog. How to get rid of?
    DO NOT USE BARS LEAK!! It'll clog up your coolant system.
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by andremike View Post
    Well in my personal opinion and from what people have told me u shouldn't use a radiator stop leak or anything like that. I've read that over time it causes thongs to clog that shouldn't be clogged
    Sent from my pager using Morse code. ... .. ... ....
  14. #34 Re: Window fog. How to get rid of?
    Nov 2009
    chicago
    Ok guys I won't use it... I wish I knew for sure that was the problem.. I'm still not sure. I can tell you that my windows are fogging pretty bad and I have never experience this before. I don't have any water on floor board so I'm notsure what it is..
    I have been topping off the coolant lately.. light would flicker, id top it off and it would stop flickering. In some time the light would come back on and id top it off again.. would I smell that sweet coolant smell in the summer? I thought I remebered smelling it then.. but not so much anymore.. by the way.. my lim and uim all were replaced about 6 months ago..
    So what else can I do or look for? If it is the heater core, what is that ging to cost me? What else should I replace? Blower motor? ???
  15. #35 Re: Window fog. How to get rid of?
    pull the carpet up and check if it dry underneath. the carpet has inches of foam under it and it can hold water, or coolant just fine, while hiding it. you need to pop the door sill molding up, and the front plastic kick panel to show the hooks the carpet is held on to at the edges.
    you can also check the outside heater hoses, one of mine was all swollen and leaking down the outside of the firewall, and causing fogging of the windshield as well.
  16. #36 Re: Window fog. How to get rid of?
    Nov 2009
    chicago
    Thanks, ill try to do that this weekend. I am having severe fogging on all of my windows.. really bad. They are so fogged that water is dripping down. I have to open the windows to clear the fog.. is there anything else I can look for or at?
  17. #37 Re: Window fog. How to get rid of?
    is the heat coming out of the vents hot? no heat at all will fog window pretty fast in the cold air.
    if its hot id really lean in the heater core as the problem. they suck to change honestly,( but really it could be worse) but doing it your self is well worth it vs the price a shop will rape you with.
    i will cost ya a afternoon. or less depending on your skill level. lots of small bolts to get to.
  18. #38 Re: Window fog. How to get rid of?
    Nov 2009
    chicago
    its hot.. really hot.. i have to open windows to cool off.. but still cant clear the fog. unfortunately I could not do it myself.. and will wind up paying through the nose... So if it is that. then what else should I replace? heater core, any recomendations on which one? I already have the hoses to the core should I do the blower motor?
  19. #39 Re: Window fog. How to get rid of?
    heater core is just that, just that part needs to be changed. if you can build a model you can open this up and change it. your working with plastic parts the whole time till you get to the core. remove all the small bolts, pop a part off. its just uncomfortable to work at due to your on your back hanging out the door with a light next to your head so you can see, then get up and find the bolts on the other side, so its a back and fourth game for a few hours.
    it "WILL" go back together faster and easier then it came apart, i guarantee it lol
  20. #40 Re: Window fog. How to get rid of?
    Nov 2012
    Madison
    Just like Scotty said
    I did my 2004 a couple of months ago. Really not bad at all. I bought a Delphi from Amazon for like $70.00
    Once you get going, everything seems to fall in place. Patience would be all you need,unless you have hundreds of dollars to throw around for a shop fix.
    My windows were slimy fog before I did the repair,actually quite dangerous to drive.
  1. Window Problems
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2008, 05:02 PM
  2. Window Vents
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 09-03-2008, 08:34 AM
  3. Window problem
    By dbean in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 05:09 PM
  4. My Window Is Stuck!
    By Guitarist575 in forum General Tech Discussion
    Last Post: 05-27-2008, 12:30 PM
