Thread: TC off at start....is it possible?
Results 21 to 40 of 44
  1. #21 Re: TC off at start....is it possible?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    no its not a problem its just annoying to do everytime i get in the car
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #22 Re: TC off at start....is it possible?
    That sh1t is $35 shipping, lol.
    PULLING THE FUSE IS FREE PEOPLE!
    Good lawd.
  3. #23 Re: TC off at start....is it possible?
    Oct 2011
    Michigan
    abs saved my car once when i needed to make an emergency stop that involved steering thats why i dont wanna pull the fuse....i hate ABS in the winter time
  4. #24 Re: TC off at start....is it possible?
    ABS sucks, 110% of the time.
    If you know how to drive, you don't need it.
  5. #25 Re: TC off at start....is it possible?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I hate it in my GP but in my Oldsmobile it's welcomed.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    I think my button is shot... It does NOTHING.
  7. #27 Re: TC off at start....is it possible?
    Quote Originally Posted by Kolton Lock View Post
    maybe the bulb is out in the dash?
    have you tried to spin the wheels in dirt or loose gravel? if so the low trac light comes on, then click the button, and try again, if low trac comes up again you have a issue. like a bad connection. maybe like the plug on the switch.
    Mar 2012
    Minneapolis MN
    I can tell you my bulb isn't out cause the low Trac will come on when spinning wheels. But no matter what I do, short of pulling the fuse, I cannot get the Trac off light to come on via the button
  9. #29 Re: TC off at start....is it possible?
    pull the switch, see if its still plugged in.
    Mar 2012
    Minneapolis MN
    Pull the switch? You mean take out the whole DIC? Cause on pretty sure I can't just pop the button out
  11. #31 Re: TC off at start....is it possible?
    Pop off the dash, remove screws.
    Remove DIC.
    Pretty straight forward.
  12. #32 Re: TC off at start....is it possible?
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    Quote Originally Posted by acidcrashdburnd View Post
    The Easy Performance module is garbage, I'm making this statement from experience. If you want something use this, I have one installed and it works great.
    http://www.grandprixforums.net/tract...ule-61304.html
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
    Mar 2012
    Minneapolis MN
    K removed everything. Replaced the Trac off bulb and now that is constantly lit up.
    Mar 2012
    Minneapolis MN
    Also the button does nothing and was attached. No wires going to it though. Unsure if there was supposed to be
    Mar 2012
    Minneapolis MN
    So to correlate this to the OP... Mine is already off at start
  16. #36 Re: TC off at start....is it possible?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by asite57 View Post
    thanks blue i just found it hard to believe that all you do is swap those 2 wires to fix such a big problem
    You better re-read that. You have to solder two wires to the circuit board, which come from a relay that you have to wire.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #37 Re: TC off at start....is it possible?
    Oct 2011
    Michigan
    Quote Originally Posted by Bronco Boy View Post
    see i knew i couldnt be that simple, if i get my car dyno tuned for other mods could they tune the car to have the button off at start
  18. #38 Re: TC off at start....is it possible?
    Oh for christs sake.
    Just push the button.
  19. #39 Re: TC off at start....is it possible?
    Apr 2012
    Middletown DE
    DON'T YOU KNOW WHAT HAPPENS WHEN YOU PUSH THE BUTTON?!? The paint wears off over time JUST LIKE THE STEERING WHEEL CONTROLS, It looks unsightly. OMG.
    1993 Oldmobile 88
  20. #40 Re: TC off at start....is it possible?
    Yeah, guess pulling out the fuse too...or soldering two wires is too much work.
    But who am I to judge, right?
  1. Not sure where to start...
    By bilak09 in forum Engine
    Last Post: 01-06-2011, 01:46 AM
  2. Help, Car Won't Start.
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2010, 09:58 PM
  3. Car won't start
    By Green38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-26-2010, 12:26 PM
  4. where to start
    By bitterpill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2009, 10:46 PM
  5. Where to start?
    By mminchau in forum General Tech Discussion
    Last Post: 05-31-2009, 10:51 AM
