11.5 afr commanded, shoots up to 11.9? 12.5 and .7KR, so 13 commanded. stock pcm commanded 14*-16* with commanded AFR of 11.1
Originally Posted by Nixon 11.5 afr commanded, shoots up to 11.9? 12.5 and .7KR, so 13 commanded. stock pcm commanded 14*-16* with commanded AFR of 11.1 What? No. Look more closely at the stock programming. AFR changes depending on time in PE and RPM, so there are dozens of AFRs. Also, stock spark goes as low as 9* at high airmass, high RPM. His car is running the stock tune normally as it should.
Forum Rules
