Thread: Shutting off/flashing dash lights in reverse.
Results 1 to 7 of 7
  1. #1 Shutting off/flashing dash lights in reverse.
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    So since the other night while driving home I go around a turn hit a rather large bump and bam, all my lights shut of, headlights, instrument cluster, radio, subs, and the car sputtered then the lights came back on and car coughed and started running smooth again. Had 1/4 tank of gas and was scanning it and nothing was out of normal operating range.
    Next day go to back out of driveway, put it in reverse and lights go haywire(all the above mentioned lights) and car shuts off.
    Now random bumps in the road set of the lights flashing and resets the radio and abs/brake light stay on.
    Im thinking its a ground wire loose possibly? Thoughts?
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  2. #2 Re: Shutting off/flashing dash lights in reverse.
    Apr 2009
    Fort Worth TX
    Check the obvious stuff first:
    Battery cables - battery secure?
    Hot wire to starter - Ive seen this rub on the rad support and ground out when hitting bumps.
    I know it sounds stupid but it could be your ignition switch.
  3. #3 Re: Shutting off/flashing dash lights in reverse.
    Rico nailed it..
    Likely a loose battery cable.
  4. #4 Re: Shutting off/flashing dash lights in reverse.
    GT Level Member GMCustomerService's Avatar
    Michigan
    dazedandconfused,
    I agree with the "rico" too. If that doesn't fix the issue, consult with a certified technician for additional assistance.
    Please keep us posted.
    Louis
    GM Customer Service
  5. #5 Re: Shutting off/flashing dash lights in reverse.
    Louis..you forgot to agree with me too. I feel left out.
  6. #6 Re: Shutting off/flashing dash lights in reverse.
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Quote Originally Posted by GMCustomerService View Post
    dazedandconfused,
    Louis
    GM Customer Service
    in other words.. give GM moar money.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
    Sep 2011
    bedford, Pa
    Pulled both terminals, retightened, and works like new, guess something that simple is a good starting point. I was already trying to figure out body grounds etc lol. Thanks Rico and Mr boosty!
  1. Dash Lights out and Tail Lights out on Pontiac Grand Prix 2002
    By aaronman in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 08:31 AM
  2. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
  3. Flashing lights mean get out of the way...
    By Paramedic in forum The Rant Forum
    Last Post: 08-11-2011, 06:49 PM
  4. Interior lights flashing
    By JoRoW99 in forum Audio, Security & Visual Electronics
    Last Post: 06-10-2011, 08:43 AM
  5. interior lights very dim,shutting radio off.please help
    By dvandemark in forum General Tech Discussion
    Last Post: 12-06-2009, 05:06 PM
