Ok... So I sifted thru about 4 pages of a/c threads on this site and didn't see anything that matched what mine is doing. I have a 2000 GTP with dual climate control, two little sliders that go from red to blue. If I have the dial set to max a/c, the a/c button lights up, and I get air movement. If I slide the sliders all the way up, hot hot air comes out, slide it down, cooler air comes out, can hear something moving, assuming blend door, but not 100%. Air only feels cool as in forced air cool, not conditioned air cool.
The odd thing is the fact that the a/c clutch is engaging, a/c fan is kicking in, and the system pressures are all perfect, drops right to about ~35 psi on the low side while running. Everything seems to be working, but no -cold- air on either passenger or drivers side. Never had water on the floorboards, I can physically watch the pressures drop from equalized when the system is off, to right where its supposed to be while running. Any help with this would be seriously appreciated!!!
