Quote Originally Posted by Averix View Post
So basically I'm going to have to track down an adaptor for my high side. And yea, I was checking the lines by the firewall when they asked me to check the evaporator, was the only place I could access it lol. Ill check the accumulator today after work and see if I can scrounge up a fitting for the system. Also since I don't see any tx valve on these things, does it use an orifice tube? If so, would they get plugged and cause an issue like this? Either way I'll post back with my results once I get a gauge hooked up to the high side.
I think thermal expansion valves are a thing of the past for the automotive industry. The accumulators are strange animals. They work in conjuction with the orifice tube as expansion and drier.
I guess they can get clogged but all the oil will get pushed into the evaporator and probably trash the compressor. The high side pressure would go through the roof. The low side may go to 5 or 10 psi.
Maybe someone with a little more expertise will comment. I'm just a weekend warrior. Every car I have owned has had AC problems.
